XiaoMi MiPad
yhw22
LeTv
lots of chinese dramas :D chinese movies occasionally.
if u download LeTv in singapore... will not be able to download unless using vpn.
You can try Youku too. No need VPN to watch China drama also allow downloading. HK drama can only stream online w/o VPN too. :)
koxinga
Anyone can easily buy Mi Pad case in China? Heading to Guangzhou for business trip next week so thinking of picking one up.
yhw22
Yes. It is local brand and popular so no worry. And moreover it is been released for more than half year in China. Just that singapore just start to sell once only.
d3n
Thanks Dennis for organizing the MO, really fits like a glove with automatic wake/sleep on the flip cover :D
yup i am surprised that the fit is so good also :D
cheap and good! the only drawback is the case is a bit heavy and plus the mi pad its even heavier! :s13:
daymond85
first thanks Dennis for bringing in this case and , of coz, my wife cartoon case.
I agree with you that this case with mipad shows a bit heavier as compared to my wife cartoon case. Hownever, it works prefectly fine for me.
Now finally can paste my tempered glass SP which I bought separately from qoo10 and this case. Previously using it nakedly with original plastic cover. Haha ....:s13:
My pasting skill so powerful. No dust at all. Haha...
d3n
wah rau... i spent 1 hour plus pasting the normal screen protector that comes with the case... still have some dust but not so obvious... think i will use at least 6 mths then change (this time pay for the shop to paste :s13:)
eyz
actually the pasting part is easy.. the dust extraction part is tedious!
you see a speck of dust and you decided to remove it. so you lift the sp up and use the tape to tape it out. the moment you stick your sp back, you see another speck of dust at another location!!
d3n
dats what happen to me... somemore the screen is 7.9"... so bigger space area for dust to enter :s13:
Mr. Bushido
How come when I connect the MiPad to my MacBook via USB, my MacBook cannot detect? Cannot transfer files to my MiPad storage... Can someone please help :s12:
d3n
i try tonight to see if i have the same problem.
could be the file system problem.
daymond85
Haha... no issue for me. Do a house cleaning before pasting it. :s13:
Make sure ur surrounding area is dust-less....:s8:
kashix
Can Anyone post a video of how well this thing run hearthstone? Thanks in advance, wanna see the gameplay whether smooth anot. Any hearthstone users?
SpaceMonkey
dear XiaoMi MiPad Gurus,
recently i bought a mipad from qoo10. its a gift for my dad.
i tried installing Google Play on MiUI 4.2.27 (beta) with google play (version 5.2.13), it doesn't work and it keeps crashing.
can anyone help me with this?
Thank you.
arcturuz
nvr tried on ipad b4, but it is smooth on mipad
Atb
Thank you.
search for google in mi market. Or google google installer in the miui forum. Download the apk and install. Follow instructions for the google installer available on the net.
mingfreakrsx
Thank you.
Download the Google Installer app from Mi Market here -> Google Installer , but first ensure that you have the Mi Market app at your Mi Pad. :)
Sent from my Mi device using GAGT
