Car Vibrate when idle
croc1977
Hi,
My car is vios 07/08
When i start my car or idle ...left front side of my car will got vibrate sound....
when moving maybe 30km/h and above i don't hear it.
and when i move less or idle mode then sometime got vibrate sound ..sometime no...
and if i switch off the aircon when idle ...there isn't any vibrate...
so i ask around my friends they say either air con fan belt or timing belt..
any advice on the cost i will be looking at?
kebinu
maybe compressor? loose belt? engine mounting?
best is to go workshop and see the actual problem
Jeffrey.ling
Bought engine mount.. cheapest after comparison.
Can call and ask...stockist...
Chin Hon Motor & Trading Pte Ltd
Address : 62 Race Course Road S(218568) (map) spacer
spacer
Phone : 62963915 spacer
spacer
Category : Accessories Retail, Car Parts Stockists spacer
spacer
Brands Carried : Kyb, Cherry, Oozx, Taiho, Mk, 555, Daido, Npw, Ford, Mazda, Kia, Honda spacer
spacer
Description : Retails car spare parts with installation.
wacko
with 50% of car population aged 7 years or older, guess we will see more and more of such threads for a while...
Flex11
high chance is engine mounting.. but best to check with mechanics first la..
dont anyhow listen advice then go buy wrong things and waste money
newcell
Why not open up the bonnet and see anything shaking that might cause that noise
connected
Engine Mounting..because I have the same problem, when workshop and that is what they say, but engine won't drop one la, don't spend extra $$ =:p
Beepok
It will stress the 2 other mounting and soon your car will vibrate like crazy. Engine mount quite cheap. Even for my cx7 only $400 for one. Change la
croc1977
never mind...resolve liao..
my fault.....the bonnet holder place wrong place...causing it hit against chasis...
paiseh
viosATwork
Hi,
I'm driving vios 08 and also having vibration problem when idle.
From what i observed, the vibration occur when the rev is ard 500rpm.When air con compressor kick in, the vibration stop temporary and vibrate again when rev drop. The vibration happen almost every2-3 days, during red light and not during cold start. Not sure if it's engine mounting or other problem.
Anyone can recommend a car workshop?Thanks
croc1977
clean throttle body?
viosATwork
The car mechanic clean the throttle when i went servicing ard 2-3 mths ago. Inform him of the rpm and vibration but he say it's normal and he didnt feel any vibration.
If anyone has any recommended workshop, do PM me.
newcell
Axio manual
Vibration during stop and idle Only.
Check and adjust all 4 spark plug gap, 1.1mm
No more vibration after the above done.
fatboy71
could be engine mount worn
