Xiaomi Box Android TV Box
yhw22
Ya rakuten, stated as Dhl also but toll came. Ordered on 10th night time
Same too, still waiting for mine to arrive.
Just checked from toll and is out for delivery 9.21am. I kept search DHL but no find.
Just Me
i also thought so. But I think it depends on your needs. Mine is a original stock firmware box. For now, I installed Kodi, HDPTV, Togic, and Shafa (actually I will rarely use shafa I think), and I feel more than enough for me. Since I seldom watch streaming, the original xiaomi player and Kodi are sufficient. HDPTV and Togic are just for me to try out.
As of now, no rooting nothing for me to do.
Maybe, I need to find stream source to watch live football on Kodi or other app.
mibox can run view streams in kodi with hardware acceleration turned on?
chengsun
stock firmware cannot, must be rooted then can hardware acceleration.
im using software acceleration, OK for my usage for now, so I did not root yet.
Just Me
Any guide for rooting so that hardware acceleration can be enabled? Thanks..
ZynoXII
hi guys! i have tried 光芒体育 and it's finally loading :)
however, the fps is quite low, quite choppy, is that a normal problem or is there a setting i need to change?
gregory_choo
this apk doesn't like xiaomi box. smooth on other boxes
galliano
Oddly, the big mibox no. But the new mini mibox all the acceleration are turned on w no problems.
asriznet
qwer71
Anyone managed to run acestream on mibox?
I dl p2p stream and was prompt to dl acestream client but I could not locate the path
Sd/download
Just Me
This Article should work.
My Mi Box is running 1.3.73 rooted.
The original one will be this article
You'll need google translate if you don't read chinese like myself.
Thanks for the guide. Just one part I need to confirm though. The root app is launched from the pc and did you update to the latest firmware prior to rooting? An empty sdcard smaller than 32gb must be inserted in the box as well?
asriznet
My mi box was on 1.3.63 i think when i did the root process
if you have not installed the USB driver for your mibox on the pc, you need to do that first. I just installed shuame on my pc to get the USB driver installed before using the root script. Rooting using shuame will mostly fail on the mi box but it helps with the driver installation.
I formatted my 64GB micro sd card to a single 32gb FAT32 partition in preparation to root my mi box.
i think you should download the root package from the one drive as that includes english version or else your command prompt will be gibberish.
