Games stutter badly
Beepok
Had this problem for quite a while, i changed my cpu because i thought it was cpu problem, but the problem still exist. My rig specs: 1600 8gb, r9 285, i5-4690k. Games like far cry and watch dogs is 60fps smooth most of the times. But certain times it will stutter badly and go to 10fps for a few seconds. What is the cause? Is it hdd problem? My hdd is normal wd blue. Anyway to test the root cause?
halnala
Post full spec. Including PSU model and wattage.
Goodshot
? What is that? I install the amd evolved client and the catalyst thing
This thing lo , anyway 280x run AAA tittle already just pass , 285 worst
Beepok
weird leh....fpr me, my game run at 60fps 90% of the time. Just that sometimes will drop to 3fps. if its constantly 30fps then its my settings problem.....but most of the time is very smooth leh
shadow84
This software is useless, IMO... Used once and it gave me high settings for my games when i could have pushed for very high/ultra.... Uninstalled it after that and nvr used liao...
Goodshot
Try off all AA ba , lasttime my hd7970 ghz also like this , i off AA ok liao. Dun like to play with AA on anyway
Goodshot
This software is use when maybe u kena problem with game / shattering shitt. Wasnt ask u to push high fps/ performance with this software. U wan push high = Buy better card
Godeau
A lot of things going on onscreen then will drop or? If yes then try reduce some graphical settings. Anyway, can you test by just sitting there idle in-game, see whether fps will fluctuate or not?
Also, since it's a fresh install, try turning off Windows Defender, Disk defragment scheduling, System restore, and lastly in Power options set to high performance.
Edit: u might also want to turn off automatic windows update, it might probably be downloading and installing while you're playing games
shadow84
Not about pushing high, but giving me crap recommendations for settings when i noe my gpu can go further.
Beepok
Solid 60 if nvr move ard. No windows update one my comp. is just bare windows 7
