It depends what you look into in iOS.
I posted a video comparing 3GS running iOS 3 vs iOS 8 on another device (6 plus I think).
They focused so much on the visual aspects until it negatively affected performance and responsiveness.
iOS 7.1.2 was golden for 5S (for me), after upgrading to 8 and above it suck big time.
Running 8.1.2 on 6 Plus I also feel sluggishness, now 8.3 very smooth.
Only problem I spotted so far since 8.3 upgrade, is the inability to select photos from Photo and export via telegram.
8.3 now?![]()
What problems are you facing?
1) Basically stuck with 7.12 since ppl have, generally, experience issues with 8 onwards.
2) due to 1. Certain of my app feature cannot be used. Not to mention some apps require min 8 to work.
Take my response lightly though. It's basically just not as responsive.
other than
1. e botched update for 8.0.1 which caused my 5s to crash n b stuck in a reboot loop
2. e higher latency in e wifi,
iOS 8 has worked ok for me.
I encounter some app can't be used after iOS update
