szeli
- Mar 24, 2003
how is cisqo still alive??
Barry probably runs back into e speed force n back to b4 Cisco was killed n stops Wells?
and how did wells end up in this time in the first place.. if he is from the future..
If I'm not wrong, Eddie Thawne should be the father of professor zoom (reverse flash) and thats why he never killed him during the lab confrontation.
actually it has been stated that speedster who tapped on Speedforce are able to time travel...Tachyon technology......but he only did it once and lose the ability to do it again (maybe his fight with Barry spoilt his time traveling device).....and Flash can do it without using an exterior power source....
But then again, sometimes, DC comics is inconsistent. For example, Superman could travel faster than Flash at certain times but you will never see him time travel.
you haven't watched enough dragonball.... lol....Awesome episode indeed! but i still dun understand how dr wells make another of himself out?
The Flash Rebirth
one of line read
Clark (Superman) tells Barry (Flash) that he can’t outrun him because, as their earlier races have proven, he is just as fast as Barry. Barry turns to Superman and says that those other races were for charity and proceeds to kick it into another gear and leaves Superman in his dust.
for reverse flash they draw on negative energy or something hence they are able to move fast but unable to time travel without external help....
Sent from an account getting banned soon without using GAGT
erm... we did see him run fast without the suit more than once.... maybe without the suit, he can't tap onto the speedforce and can only draw a small amount of it, after which he become normal....the reason y reverse flash exist is cus he found the flash's suit in the future many thousand years later. the suit the flash wore throughout his career got all of the flash's energy and tts y he can only run fast while wearing the suit, once outside the suit he cannot run fast.
he use the taechyon technology device to empower the suit even more so he can tap the speedforce without the suit
According to what I read earlier in this threat, Eddie may be well's grand or great grandfather of some sort. Because wells is from the future.please enlighten me.
Wells is Edward thorn aka Eddie father?
Sent from The USCSS Nostromo using GAGT
then if reverse flash is stuck in current time line, then where the red flash ?
