Qooo10 selling 1,299 with sound bar and sub woofer.
Shipping it in will cost 1.1K. without sound-bar and subwoofer.
Anyone bought from Qooo10?
Qoo one is jailbroken, how important is this? Or simple to jailbreak by ourselves?
I just bought mine from a seller on Qoo10. Took only 3 days to deliver. They helped me to root and set to English along with installing quite a number of apps; some are their apps, need subscription and username to login, some are apps cracked by them.
However, I'm encountering some issue where my apps intermittently exit. Not sure what is wrong. I'm running Synology NAS at home and installed DS Video into the TV and stream from there. MX Player was installed and used to play the videos. However, after running for like 3-5 minutes, the video would exit. Any ideas why?
I got it through a fellow Carouseller. He's friendly & prompt in responding. He doesn't sell this specifically. He's just bringing it in together with his goods for his other business. You can get it through Taobao & use 65daigou to ship it in for you too.
Bear in mind that all this is at your own risk though. He only guarantees for the shipping for no crack or damaged panel on the TV. Good Luck !
Yup. That's the link.Hi, is the seller based in Sg? is this link the one that u bought? tks
Qoo10 - **LOCAL SELLER**
Called and text the seller from Qoo10 but no reply.
It is android, so I think it is easy to JB.
I might ask my Chinese friend to help me buy and ship over. Or spend a bit more to get a japan brand with warranty.
Standard DvB T2. Tuner.
Saw Panasonic 4K at 1.7K+.. will go check do more research next week.
LG new 2015 model 700T @ $1049. 42in. 4K Tv with smart remote control. 3 years warranty. New 4 color led/lcd display. (3 usual color plus additional white).
Suggest after purchased. Pay a little more to get some small Andriod external player attached to tv via hdmi port. Many brand including Xiaomi to choose from. Get your main TV itself out from any potential OS bugs, especially Muiu.
bro,
care to share where to source for this?
I found courts online 49UB700T at $1699
thanks in advance
Introducing 40" Mi TV 2 ~
[Launch] Mi TV 2: 40-inch Full HD LED Smart TV - Mi*Community
Sent from my Mi device using GAGT
Bought this TV via official XiaoMi CN Taobao store.
Can use SG credit card to pay
Now waiting for them to ship the TV over 65daigou warehouse.
I think the main aim of Xiaomi is to have a smaller and a bigger Mi TV 2 variants(which explains why the 40-inch is still branded as Mi TV 2) to suit different needs.how come the new version like a step backward? 40" only and no sound bar and woofer, price rmb1999 also so so only if you factor in freight cost.
Still prefers the 49 inch version 1... seems better.
I aint sure. Item has not arrive 65daigou warehouse yet.
According to xiaomi website. The TV with its package weight about 18kg.
Add in wooden crate should be about 30kg?
http://list.qoo10.sg/item/小米-LOCAL-SELLER-XIAOMI-TV-2-49-INCH/419227896
They are selling MITV2 in blue/black color.
Please be cautious when buying. Maybe I am wrong but accroding to my CN sources MITV2 currently do not have it in neither blue or black.
LG 49" is a good choice as it has DVBT2 tuner (which is a must now a day) and 3 years warranty.
