The Watch Thread - Part 7
tckrto
this...
it uses 9R66, no see thru caseback though, and it is pretty hefty...
SBGE029 might be a little difficult to find, but there always SBGE001 & SBGE015, but the blue guilloche dial is:love:
Not my pic....
Had a SBGE009 the movement is truly mesmerizing. Me going to get SBDB009 soon. Simply cannot resist SD movement.
Spartanz.
Went to ion panerai to try the 372 and 305 but no stock. So tried this for size. Too huge for me right? Looks like a freaking clock on my wrist.
I think it looks ok on yr wrist leh, if u take a photo close up , the watch looks bigger than usual. Try taking further away from yr cam
Spartanz.
attachment.php
Check out my watch that is back from omega bienne , notice the scratch on the 12 o'clock index :s22:, hands were replaced under warranty but watch came back in this condn.
Should I go back to swatch singapore n demand them to send it back to Bienne again ? Or just accept the scratch and wear it . This would be my approx fifth time going back to swatch singapore for a damn watch
rachdanon
attachment.php
5 times on this watch?This Ish Madness!!
Madness??
I won't accept a scratch like that that they made for a luxury watch..
If its 4 times and still the watch has issues I'd email to as high as possible in Swatch/Omega with a detailed chronology of events and I'd post it on influential forums such as watchuseek. The issue here is not the scratch per se but the 5 times and the time it has been in repair. What were the other 3 times for?
Spartanz.
Madness??
1st time- remove large dust particle in movement , scared it might enter movement, watch came back with a dial flaw , possibly the paint coating of the dial came off .
2nd time- dial replaced, watch came back with a dirty dial. Dust particles found in dial without the use of a loupe.
3rd timee- dust removed but new particles appear in other areas of the dial. Scratch in hour hands.
4th time- sended watch to Omega Bienne via Swatch Spore. Hands were replaced, but 12 oclock index was scratched :s13:
i give up liao...i already prepared my email and letter. Want to send back to Bienne again next week if possible. If no solution to this, i will sell this watch and blacklist Omega and other swatch brands.:s13:
pwillie
Pwillie.. U own quite abit of Swatch owned brands..
Any issues with servicing ? Or are you not as fussy as me? :s11:
I never go back to swatch group for servicing as I don't believe in regular servicing.
Also for omegas, it's easy to go for 3rd party.
Maybe you are right, I'm not so fussy =:p
Spartanz.
Ic , u won't service unless it breaks down? how 3rd party source for vintage parts then if need replacements
Wad will you do in my shoes ?
Just ignore the scratch and wear with pride ? Or resolve it until u r sastisfied with it?
pwillie
I won't service until there are problems with the watch.
Omega parts are generally easy to source(even online ofrei)as of now, not sure if swatch going to limit that in future.
As for your issues, can't comment as our tolerance level differs, sometimes what is seen cannot be unseen, so you just have to resolve it to your satisfaction
Omega watches are not exactly cheap, you have every right to expect them to be of a high standard.
