Hi, everybody. just did the new IPPT today and here to share something about the Pushup since there are a lot of questions about this. This was done in Maju FCC.
Pushup is done in detail of 5. Each person who is doing will be watched by 1 PTI EACH. He is positioned directly in front of you. Your assistant will be to your half left. There were other extra PTIs walking around the general area who will point out to your PTI in charge of you if there are no counts. So you are watched from front and back.
1) You will take position by lying down entirely on the floor with your arms beside your chest. NO WIDE ARM.
2) You are required to do 2-3 "demo" pushup to your PTI. He will correct you if you do not have the proper form (body straight, arms shoulder width apart, and nothing else touching the floor when you go down) You will go back into the position in Step 1 after this. This is known as the STANDBY position.
3) PTI will say STANDBY, followed by UP. On the word UP, you will push up until your arms are straight. Assistant will put his fist below your sternum (middle of chest) which is also inbetween where your palms are. This step will take about 1-2 seconds MAX.
4) PTI says GO! You whack as many as you can in 60s. everytime your chest hits the fist your assistant will count out loud. He will continue to count as long as you hit the first. PTI will say OUT LOUD when your pushup has no count and deduct it from your final score (that your assistant counted) when you are done.
Note: they are VERY particular about form. So when you train for pushup. Focus not on numbers but on the form. make sure you do swee swee first then push for higher number. The max amount you do when training should be the max you can do without BREAKING form.
Note2: You can rest when your body is up and your hands are fully extended. You can rest with your hips pushed back (like when you kena tekkan and you holding pushup position your ass in the air like that) however BEFORE you continue the pushup you must go back to a straight body before going down to the ground.
Hope I helped clarify the process! It seems very scary, honestly I quite scared before the test today. But aside from the ngiao-ness is actually quite easy to pass.
The irritating part I hate about this station is not the toughness or ngiao-ness. It's the part where we have to train for it (not the time or strength part either).
Yeah sure, for pull-ups, most of us have to go exercise corners and all to train while for pushups we can just train at home. But for push-ups, how are we supposed to train for the correct form when we exercise? Since a long time ago till now, I'm sure most of us kena tekan in uniformed groups or army before but I'm dead sure none of us really cared about form back then.
The only ways I can think of to train is to get someone to watch you when you train or to put a huge-ass mirror beside yourself and stare at your own body while you do since it's damn hard to detect any "off-form" movements when our eyes are only located at the front of our heads.
In terms of training, it's a bigger pain in the ass than pullups and in fact I think less beneficial for upper body strength. But what to do? LLST lan lan suck thumb lor. *shrugs*
Sorry for the rant btw -_-
