XiaoMi MiPad
I'mknotdumb!
i still cant figure out how to fully wipe my mipad even though i followed this
Wipe Cache - Deletes the cached system files (do it if you suspect your ROM is corrupted, or you want to flash new or same ROM)
Wipe User Data - Deletes the User Data (do it if you suspect your data is causing issue to your ROM)
Wipe All Data - Deletes User Data and Apps Data (do it if wiping cache and User Data doesn't solve your ROM issue)
Wipe SD Card - Returns your Internal Storage partition to default folders and files
eyz
this is miui recovery. you should install cwm to do your wipe.
lifesgood
i tried the below steps:
Download the file Update_CWM_recovery_MiPad_6.0.5.0.zip to your PC
Connect your Mi Pad via USB to PC
Copy the file Update_CWM_recovery_MiPad_6.0.5.0.zip to the folder 'Computer\MI PAD\Internal storage' (root folder of internal storage)
Disconnect your Mi Pad properly from USB ('Safely Remove Hardware...')
Launch the Updater app, from the menu choose 'Select update package' and from Internal storage select the file Update_CWM_recovery_MiPad_6.0.5.0.zip
Your recovery will now get updated and when finished you need to confirm to reboot
For checking after the reboot you can now reboot into CWM recovery by starting the Updater app again and choosing from the menu 'Reboot to Recovery mode'
But receive an error message saying "Update failed. Can't update at the moment. Touch "OK" to report this error to our engineers.
Anyone has similar issues?
slacker
You can follow this step to get to recovery mode
Power off your mipad
Press power button and volume up button together and release after you see mi logo
I'mknotdumb!
1.first install CMW
Then follow this steps (by DbIm4ikO)
System1: -> Wipe Data / Factory reset
-> Advanced -> Wipe Dalvik Cache
++++ ++++ Go back to (to the start menu)
-> Managed system -> Select System2
-> Install ZIP -> (Select the firmware file, flash, and then select the file c gapps, sews)
-> Managed system -> Select System1
-> Install ZIP -> (Select the firmware file, flash, and then choose file c gapps, sews)
-> Reboot system now
.........DONE.............
credit to xda
lifesgood
To clarify, did you mean to rename the file to update.zip in root folder and update through recovery mode?
d3n
eyz
take a look at carousell, there are some cheap cases and plastic screen protector around.
got my case and screen protector for only $15/-
mozaat
mipad pptv
Hi guys just brought a mipad for wife as her ipad2 recently up the lorry. She used it mainly for q10 surf and pptv for korea drama.
But.. Play store cannot find any apps for pptv. How come ar? Mipad dun support pptv? There is tudou and letv apps but really sux .
Is there any way to make mipad able to use pptv?
I'mknotdumb!
http://forums.hardwarezone.com.sg/87223982-post138.html
taker42
For apps not compatible and so cannot see in Play Store, can try download the apk from somewhere else and install. PPTV got website you can download directly.
