[AMA] I am a DENTIST. Ask me anything! [AMA] :D :D :D
SiAhBui
Not true. Depends on experience. Some earn only 7k a month. Those working in public earn around 6k inclusive of cpf but exclude bonus
Wah so 7k including bonus and commission is the minimal? That is damn awesome...
GundamKnight
is it true most orthodontist do bracers will go for textbook solution like extraction?
Do any of the dentist/ortho actually put effort to review case by case?
TCMOMS
can i dun do root canal, even though it's recommend that i do root canal
becoz if i do root canal still have to do crowning and i have no money to do both as
i jus finished doing crowning on my front tooth and it cost a bomb
Root canal is usually done only if you have intense toothache due to deep decay that has allowed the bacteria to reach the pulp(where nerves and blood vessels are) or when there is an infection
Crowning only advisable for back teeth(molar) which had done root canal. Usually front teeth no need. Unless it's already heavily filled up in first place. Crowning of premolar teeth after root canal is controversial.
TCMOMS
why time bomb
Research has show that pple with wisdom tooth has higher risk of decay or gum disease in other teeth. Moreover, most pple have slanted wisdom teeth(impacted), which makes it difficult to clean. So over long time, it will have decay, or infection. Some of this infection can be life threatening.
Litmuss
How much does a oral maxillofacial surgeon earns compare to a dentist?
whereismymilk
Sometimes when I eat hot/cold food I'll experience pain in my gum. What's the cause of it ah:s11:
Remedy95
Hi Doc, recently made a mouth guard with a dentist for my bruxism. Now suffering from bleeding gums on my upper jaw (guard is for the upper jaw). Could the problem be with the guard being to snug of a fit? is it common practice to not give some allowance? thanks in advance.
Sent from Samsung GT-I9505 using GAGT
TCMOMS
Not true. All patients are treated case by case basis. Orthodontist spend 3 years full time to study. So they are well trained.
birdsandberries
Well the dentist said one of my tooth has deep decay, but i dun have any intense toothache...
Oh so u mean if i do root canal i dun necessarily have to do crowning?
And i did my crowning for my front tooth becoz...
I broke half a tooth, impossible to paste back (i fractured it in secondary sch n got it pasted back), and had to do double crowning coz my remaining tooth was too small and they had to do a base first and then the final crowning. pffft.
No more opening bottle caps with my teeth :X lesson learnt
itsmee
how much to do polishing, whitening and tooth filling?
is it true that most clinics mus wait weeks to get appointment, especially those clinics with subsidies scheme like chas card??
Eddied
i broke my first molar and was told by a dentist that it will decay if i don't do root canal, like expensive leh but i got chas blue card, what's the best route for me?
SiAhBui
Did any of your female patients try to initiate affair with chiu?
