[Software Update] iOS 8.3 discussions
arcturuz
can confirm the wifi signal has improved
usually when I am at my office lift lobby, there will be no more wifi connection
today with iOS 8.3, i can still connect to my office's wifi at the lobby
swgj86
Hold down the emoji you want to change
SingTel does not support iPhone's VoLTE at the moment
doesnt seem to support voLTE now.
tried that w my friend on singtel network. both iphones updated to 8.3. but the network sign is 3G, not 4G during the call.
sogatda
yup can confirm iOS 8.3 still have this problem. Especially for messages. (happens more to old imessages than normal sms)
u try to find a very old message, spotlight finds it, u tap on it, it opens the msg thread in msgs but does NOT scroll to that nor highlight that exact message. it jus brings u to end of the msg thread.
also sometimes still have the problem of having empty list despite spelled correctly. have to go spotlight settings and 'rearrange' some items to 'refresh' it.
anyone still having issue with spotlight search. sometimes i type in characters spotlight cannot find the apps. empty list when spelled correctly. have to keep trying closing and opening apps and try spotlight again..
hope the new version helps solve the bug
sogatda
the emoji system is broken zz.
even if on your ios 8.3 device u set the old color of that emoji, u send it out, it appears together with an alien icon on non-ios 8.3 devices.
the only way to ensure it appears without that alien icon on non-ios 8.3 is to use the default yellow emoji on your ios 8.3 device. u see yellow but non-ios 8.3 will still see the old color without the alien. :(
That yellow emoji is damn racist. How do I change the default to another skin tone?
Thoma5
haha thanks.....now updating...actually y u all have so many bug in ur ip arh?:s11:
tec_geek
*adiBOY
Yes the other party you send the the emojis to has to be on iOS 8.3. All the new emojis will only be supported on iOS 8.3. That will entice people to upgrade.
chester121
hi
using 1p6+
but when i check for update , it say IOS 8.2 and it is up to date .
any one can help,
how to update to 8.3.
thanks
Rmb someone saying Singtel likes to block the updates. I experienced it too until I switched to my WIFI and refresh before the update appeared.
Kyubi
how come mine no updates yet. . still say 8.2 is update to date z
Snoweagle
Updated both my mini 2 and 6+ to 8.3 a while back and so far so gd.
