Flash manually lah guys.Download to phone, then just go to bootloader and flash from the phone itself.
i got the phone upgraded by flashing but the signal keeps dropping...
anyone has the same problem ? Starhub LTE line subscriber with china OPO set.
But someone feedback signal jialat after flashing. I think I better wait for OTA.
Hmm, I have encountered similar problems with my opo even when it was on cm11s. It will intermittently lose signal and have no bar and only go airplane mode and back will reacquire the network. So far after cm12s it was stable.
I wanted to wait for OTA, since that's the simplest. But the waiting was bothering me, limpeh keep checking Updates, and it's such a waste of time. Decided to bite bullet and download to flash.
I downloaded the file from: http://bit.ly/1DCUZlC
1. Transferred file to phone.
2. Boot into TWRP recovery by pressing Down Vol + Power buttons together.
3. Wipe Davik and Cache.
4. Install file.
then it gave me an error. tmd.
So I had to download and install the latest and greatest version of TWRP 2.8.6.
5. You can download the TWRP app on Google Play if you are rooted, else have to sideload if your current TWRP is below ver 2.8.4
6. Flashed the CM12S file finally, and
7. Wait long long at new boot animation. Almost thought phone hang. First boot after CM12S takes a while.
8. Enjoy.
I miss the CM11S lockscreen shortcuts. You get some, you lose some.
What! no more gestures? That is the coolest thing ever! Second to MOTO twist cam. (No the Play store app doesn't work reliably)
SURPRISE !!!!!i thought who nightingale... is u!
No need wait, just google it lorCan you screen shot and post here?
No leh, wifi quick toggel in the pull down menu works. i use everyday when i leave houseThe LTE on/off and wifi quick toggle is broken right?
My phone no LTE plan so i cannot comment on LTE
Think I got a bad flash, have to go back and reflash again. WiFi can't turn on
how to change the sound settings now?
Last time in CM11 , there is a quick toggle to switch between Sound / Vibrate / Silent / etc ... now there isn't any?
Welcome to the kind of crap that Google put into lollipop.how to change the sound settings now?
