air con cleaning (starmex)
HI guys,
I tried to clean my air con previously, and while i did it without dismantling much, i thought it will be easier to dismantle the blower and remove it so cleaning can be a breeze. The blower was FILLED with thick black dust that no air was coming out back then. After clearing the dust, i was amazed by how much air was coming out.
If you noticed the numbering, 1 is where there are screws, after unscrew, the blower can be tilted downwards abit to do cleaning. The right side (number 2) cannot be unscrewed as i need to remove the motor first. I am worried that i cannot fix it back or damage the cables if i did not handle it properly.
Sorry for the quality of pic and small number.
Any experts have similar air con and can advice?
HI guys,
