Gaming desktop
waitingforyou
Hi all, im not sure whether to buy a aftershock build desktop at 1900 or build at sim lim for a better one at that price if possible. Can you guys recommend me a build at around 1800-1900? Thanks.
waitingforyou
Component List :
- Custom Paintwork : Full Metal Bright White Chassis
- Motherboard (Standard) : ASRock Motherboard H97M Pro4
- Central Processing Unit (Desktop) : Intel i5 4590 Processor (Quad Core)(6M CACHE, 3.3-3.7 GHZ)
- Thermal Compound : IC Diamond Thermal Compound CPU + GPU (Free Lifetime Thermal Compound Re-pasting) *Promotion*
- Cooling System : Standard Stock Fan Cooling (CPU)
- Random Access Memory (RAM) (Desktop) : 8GB DDR3 1600MHZ
- Graphics Card (Desktop) : NVIDIA GEFORCE 970 GTX 4GB GDDR5
- Hard Drive (Desktop) : TOSHIBA 1TB 3.5 INCH HDD (Buffer Size 32MB)
- Second Hard Drive (Desktop) : 120GB SAMSUNG EVO 850 SSD
- Operating System (Desktop) : Windows 8.1 64 Bit
- Chassis Fans : Standard Chassis Fans
- External Optical Disk Drive : External CD/DVD RW Drive
- IT SHOW 2015 Packages : Trend Micro Anti Virus Software
- Warranty (Desktop) : 2 Years Parts Warranty (1st Year ONSITE)
s7460597
Think paying for the support which is supposed to be excellent from feedback.
What's the approx cost if we get parts from trade PAC or PC themes?
huanlo2
the onsite support is only for 1 year, not worth it i guess
for 1.9k, you can get higher specs if diy
shadow84
I5-4460 + asus b85 vanguard
Crucial 2x 4gb ram 1600mhz
Seagate 1 tb
Seasonic g450w psu
Total: $553 from tradepac
Msi gtx 970: $409
Samsung evo 250gb: $125
Arc mini r2: $98
Total: $643
U2414h: $300
Grand total: $1496+
i got this for my friend. Prices are after discounts, so u might get at ard $1600+ or so. Similar specs as yr setup but higher gb space ssd.
Jian19
i5-4460 + Msi h97m g43 ~ $361
Crucial 8gb ddr3 ~ $78
Lite on s900 256gb ssd ~ $138
Wd blue 1tb ~ $70
Msi gtx970 armor edition ~ $499
Seasonic g550 ~ $125
Samsung oem drive ~ $21
Fractal design arc midi r2 ~ $139
Win8.1 64 oem ~ $125
$1556 buy and diy @ tradepac ask for discount. If wan a even better gpu can consider gtx980 which is around $300+ more ~ . if buy from pctheme is around $1600+
shadow84
Wd blue 1tb ~ $70
Msi h97 g43 and seasonic g550 oos le. Last i saw, tp left with 1x g450.
shadow84
I don't know how to diy can go buy the parts at tradepac then ask them build for me?
Buy from tradepac, bring to #02-32 and ask nigel to assemble for you for a fee.
But best to ownself do, defeats the purpose of 'Do-It-Yourself" concept if u ask someone else to do for u. Can learn frm youtube.
Jian19
u can consider buy from pctheme and ask them help u assemble
they are also more newbie friendly :o
annoymous
yea everything is kind of idiot proof, except for the motherboard standoffs and plugging the power supply connectors
trento
for building, u should go to PC themes. Tradepac is more of a buy and diy place.
price wise, def diy is cheaper. bear in mind extra costs from Aftershock goes into things like aftersales, branding etc.
The case is nothing special. Looks like an NZXT S340, which is not their top of the line case. Only thing is this case isn't available here i think. With the savings, u can opt for their top line case, H440 or other cases as u desire.
DIY is a journey. These days, it's easier cos there are so many videos on youtube, websites to show u. but ultimately, its really up to the individual cos some enjoy it, other don't. anyway, i only started recently. and after a few months, realised it's not tat difficult and quite fun actually
shadow84
Read the manual? It is there for a reason .... At the back of the connector, there is an arrow which indicates that that side is positive. Just need to follow.
waitingforyou
Ok thks you guys..
Is the stock processor cooler sufficient or shld i opt for the water cooling ones?
waitingforyou
Thanks all i think i go with this specs ba
Wd blue 1tb ~ $70
The two part oos is there any other alternatives you guys can recommend? Thanks much
shadow84
Wd blue 1tb ~ $70
Wait for 1 more week, superflower leadex gold 550/650w will arrive.
As for motherboard, PCT has 1 stock last i checked. If not, can go for ASUS b85 vanguard.
katata
How your ask for discount at trade pac? Like u go there tell them the parts then say "ehhh give me best price lehh" *wink* *wink* isit? LOL
