Google Nexus 7 2nd generation
theory_87
Moi started to has problem nowadays, want to type keyboard dun appear. Close app can see delay of 1.5 seconds. Everything seen to getting slower. Getting retarted. Hard reset a few times oso like tat. And its getting hotter at the back after use.
Brought in October 2013. Frankly, i started to realise might be the hardware lifespan is due soon.
Nevertheless it served moi well for the passed 19mths.
Should be problem with 5.0.2. Ever since i sideload 5.1 via adb, the tab is smooth and responsive again... Haven't restart my tab for 3 days whereas i need to restart once or twice per day with 5.0.2 due to lag, hang or memory leak.
missotah
why urs cannot update to 5.1? Yesday as i was rearranging apps on my tab s which still on 5.0.2 suddenly some shortscut disappear into the bubble of my live wallpapers. Then it appear in different folder here n there when i restarted. The guess is the bug of 5.0.2.
batboyz
im not going to sideload since very lehceh, going to just wait for Google to trickle down to me.
basically you need to root and install.
http://www.androidcentral.com/here-are-android-51-ota-update-links-and-how-use-them ( if device brick don't find me :p )
You must be joking right? There is no need for root or unlock or anything to sideload. It's sideload not flashing which you will have to wipe/factory reset plus additional steps to do when flashing.
Bro, how to side load 5.1?
Download the OTA zip (important OTA zip not factory image, they're not the same)
Boot your phone to recovery
Choose apply update via adb
Connect ur phone to your PC via USB
Type adb sideload <ota file name> on terminal
That's it, wait for it to finish updating and reboot.
OTA file links
OTA sideload instructions with screenshots
theory_87
You don't need to root to push via adb.
Mine already updated to 5.1... :s11: got fed up of the 5.0.2 bugs and decide to update via adb since we still don't know when will google push the updatw via ota to everyone
derazor
I just gotten my 5.1 this morning via OTA.
Have to test test and see if it helps.. btw these few months the battery is deteriorating not sure if it's coming of age or is it because of lousy fw.
lordlad0
adb sideloading ota zip doesn't require root or bootloader unlock.....it's basically you using the manual download ota zip package and do it yourself instead of waiting for google to push it to you...
fastboot flash <command> .....now this is the one that requires bootloader unlock...
rooting is NOT required for flashing images via fastboot!! Root is on the OS level, fastboot took place even before the OS is booted.....think of it as the BIOS/EFI of a PC.....
derazor
upgraded to 5.1.
very smooth and speed is same like 4.xx firmware.
no memory leak and no battery drain.
Thumbs up, google!
missotah
anyone notice, N7 2013 the micro usb plug in is different from other tablet or hp that use micro usb. normally u see the usb logo on top, u plug in but for n7 it is the other way round.
Rickosw
5.1 is here
Confirm 5.1 is here (169.7mb) via OTA
have anyone notice, this time around ... Google "FINALLY" release updates faster on the Nexus products than OEM ...
you can go back in the forumn, previously other OEM was getting faster updates than NEXUS ....
derazor
enjoyyyyyyyyyyyy
theory_87
It the same micro usb. Just different orientation of the usb socket. Htc also implement it the same way as nexus 7
Rickosw
Same here.
Sent from Meizu MX4 PRO using GAGT
mightythor
Hi, I tried to connect to wireless@sgx using sim card method with my nexus 7 2013 for auto connect, but I can't seem to find the sim card choice in the WiFi settings. Does anyone know how to get this done? With my moto g dual sim, there is a sim choice that I can choose under WiFi settings to auto connect to the wireless@sgx. Anyone has any advice?
theory_87
Waiting for 5.1.1 to release for the lte version... I totally lose faith in android after all the lollipop saga. Hope 5.1.1 will win it back else bye android
