Pretty much.
Remember to add GST.thanks to a fellow BBM user, found out OPO now available in malaysia
https://www.maxis.com.my/oneplusone
RM1199 w/o contract
checking on service centre locations...
mehhh I find opo really mehh with the yellow tint issue. If you got this phone in july 14 then it's okay but for now not really recommended.
I have been using the screen equalizer app to balance out the yellow tint but it affects other areas like black background and when you press multitasking you can see this line there.
For eg, on black backgrounds you will see the bottom part is blue because you used the blue to balance out the yellow tint. Went to the park twice to put the phone under sun for 15mins also doesn't help. The phone gets hot after and you will be scared your chips will get fried.
So annoying that every time you reading something on your phone you are second guessing if the bottom is yellow or is it just your eyes.
I thought the yellow tinting should be resolved by now. I bought mine last year (around Oct I think), and along with several others I know who also bought around that time or later, none of us have that issue.
Nope. Because OxygenOS is essentially another custom rom.Other than unlocking boot is there a way to switch between cm and oxygen?
Sent from Xiaomi MI 3W using GAGT
I think u're supposed to press apply update if u want to update?Hi,
I got an OTA update notification for CM12S that I downloaded and tried to install. However, after my device rebooted and the green Android robot with the progress bar appeared, after a while the recovery screen appeared, giving me the option to reboot, apply update, wipe data/cache etc. If I chose reboot, the update doesn't seem to be installed, I'm still on 4.4.4.
What gives?
Hmm.. On my OPO, CM12/12S/Oxygen updates all have aggravated the multitouch problems...
CM11S 44S wasn't too bad but still, multiple fingers along the X axis won't register properly.
As such, I've downgraded back to 44S via fastboot.
