SAF IPPT, IPT & RT Questions...
j_t_fusion
attendance update is quite fast, everything else such as gold, silver, pass and ippt attempt is quite slow.
crow_nest
Ah no wonder, cos its stated there your attendance will take up to 4 working days to get updated. And it was already updated the next working day. I thought I got scammed for a moment.
hirako-shin
Hi guys, i intend to take the 5-stations Ippt in may. But the awards still the same? Is there a rise for the incentive awards or only applies to the 3-stations?
radiancez567
NS portal put my PPT target is for 5-station IPPT.
But yesterday I took 10th session IPT-IPPT for 3 stations only.
Like this counted or not? Checked NS portal attendance not updated very worried.
j_t_fusion
5 station and 3 station incentive is the same.
I booked an non ICT (normal) IPPT but unable to attend due to work.. will be punished?
will not be punished but may be barred from the system if skip too many times.
nowadays you can cancel the appointment on the same day as the session.
"Any cancellation of bookings for morning and afternoon sessions must be done before 0000hrs and evening sessions must be done before 1200hrs."
it is counted. attendance may take up to 4 working days to update.
AHS.Dirty
Has anybody tried taking the new IPPT system at SAFRA?
Do they set a speed for you which cannot be adjusted?
Heard is incline at 2.0 also?
hi folks, i m wondering how long it takes for the IPPT result taken at ICT to be updated in the ns portal? kinda scared le:(
j_t_fusion
your IPPT is manual or electronic?
mine is always electronic and it took almost 1 week before the system reflect the IPPT.
manual might be longer cos need the clerk to key in the result one by one.
AHS.Dirty
No incline la...Run at the speed you want la...Just no incentive nia even if pass.
Really ah? So the incline thing was a thing of the past only is it? Cause alot of old posts seem to mention incline for treadmill run.
Anyway, anybody knows how anal they are for the pushups?
lankileong
Swimming lesson during IPT ytd afternoon.
Don't know what is the point of having Aqua jogging in the pool
IPT is for us to get our fitness up on our weak stations.
cannonmaster
even though doing new ippt format, the situp station is still using machine? or same as push up buddy level?
yihao93
U want up ur fitness pick other band?
MBBSclinic
nowadays FCC guardroom cant find name listed for RT/IPT/IPPT & had to use sms alert on hp to verify?
