Leave No Men Behind
- Apr 7, 2015
Nope, still the same issue.
Interesting thing is that before I select the address and shipment mode (cart summary page), there is a paypal checkout option below Next.
That doesn't show up at all after keying in the address and shipment mode though. Just says no payment module installed.
Did scalp treatment only. It very cooling and sort of clear up clogged pores. Quite good!up upzz. anyone did it? keratin treatment?
Sent from from using using GAGT
for a moment, I thought project Z is actually one of bluuman's new waxes :S
any bros here carrying hdf? tried gold digger, decent but wanted to find something with more hold/volume. want to give claymation a shot. any knowledge where to get other than carousell
HDF Claymation can only create slight volume and the holding strength is not that strong.
lol. you should try dynamite clay.
the hold is just tiny bit below gold digger
but way more volume and lighter weight. lol
go to my site la. now got 20% off
arrr... thanks. How about silver fox? More hold than dynamite clay and gold digger?
Hi all,
Just wondering, how well does the shiseido powdershake work with one of the better type of hair sprays being sold here, such as PP spray?
i'm looking to add some additional hold to my hair (currently i just blow-dry + powdershake). i don't intend to use any clay / wax / pomade etc as it just weights the hair down (my hair is thin soft and flat by nature so it can't take on additional weight like clay / wax).
i stopped using hair spray 3 - 4 years ago after it ended up in extreme disaster under strong wind conditions. here's a crappy diagram to illustrate the issue:
My hair style is similar to the pic, ie: normal korean hairstyle with bangs, but his hair volume type is a little bit thicker than mine.
is the disaster caused by gatsby spray + moving rubber? hair spray is supposed to lock down the style, but when under windy conditions, the hair actually goes in the same direction as the wind, but will NOT fall back to normal state after wind stops!!!!
i remember several occasions when ppl keep staring at my hair when i went lunch with my colleagues back then, and i tot it's cos my hair is nice, but when i saw it in the mirror at the food court, i almost crapped my pants.
will those sprays like PP spray do better than this?
pls advise. tks!
What pomade do you guys recommend?
Was looking at hdf as it's water based and has good shine, that's the 2 most important things for me along with good hold.
Thanks!
Sent from Pulau Semakau offshore landfill using GAGT
