I was but it didn't develop due to some of the members time commitments.
Hopefully can find some LE players to work with
Haha yup.. Its very time consuming.. And during matches tensions get high..
Want to play together.I been stuck at SEM from 40 mm wins to 70 mm wins. Guess the vac wave bans dun affect me LOL
Do you rage in game? Me and my friend quite friendly, joke around in mumble and non rage environment.
But we only got 2-3 ppl now, so have to pug the rest most of the time and the people will rage for no reason.
Sent from Gresso Radical Black R1 using GAGT
Also seeking advise from smfc upwards... Do u guys get 144 hz monitor, and/or mechanical keyboard? Do they make a difference? Using 7 ms 60 hwz monitor wondering if I shld upgrade to benq or asus
Need so serious de ah? Lol..
Cos I see ppl die already within a 1-2 seconds... Dunno if that 1-5 ms will help me get that hs first or not...
My current monitor also quite chui 27 inch on 1080 pixel Db big plus tearing. Very hard to play
those that have not tried 120hz or 144hz will always maintain there's no difference. go have a feel of it yourself. there is definitely difference that you can see or feel. once i go to a 120hz, going to lan using 60hz is always a painful experience.Also seeking advise from smfc upwards... Do u guys get 144 hz monitor, and/or mechanical keyboard? Do they make a difference? Using 7 ms 60 hwz monitor wondering if I shld upgrade to benq or asus
i think the 144hz monitors for 24" will suffice. but of cos if you prefer a 27" then by all means.
Any model to recommend?i think the 144hz monitors for 24" will suffice. but of cos if you prefer a 27" then by all means.
i think the common ones will be asus, aoc or benq. they all have 144hz monitors
Mg1 here. can add me if you wanna play mm or casual steam nick: Elucide
