Glass Panel
idjekyll
Has anyone done glass panel case modding? I'm thinking of changing the low quality plastic panel on my Air 240 because of the crazy scratches. Can I know which companies you guys can recommend and if they can do such a small order? Thanks
sglords
why not go for acrylic sheet ?
can polish off the scratches and its cheap.
common for modding
devilwahaha
common for modding
Cos glass doesnt scratch as easily as acrylic. Some acrylic case windows can be scratched just by wiping with a not-so-smooth cloth :s22:
idjekyll
yeah that's what happened to my panel. and glass has that atas feel to it. :s13:
i just want to slap on a glass panel and not worry about scratching.
trento
no shop does it? i'm hoping to change my window too. prefer a non tinted one.
Op_Valkyrie
inwin tou for u :s34:
So smart.... Keke.... :D
