ASUS Zenfone 2
Gaminator
All this talk has got me pumped, will be heading off tomorrow to Orchard to grab a Zenfone 2 32GB 4GB RAM......though I don't really need one as my LG G Pro 2 is pretty good. But the Atom Quad core and Dual Channel 4GB RAM is to die for!
kyleongwl
Too many phones to play...need to focus a bit
Will let go my S5 & M8 for it (for the 64G variant)
G3 for G4 :)
pearl_ml
anyone having this issue whereby during usage, the battery drained very fast from 100 to 85%, and afterwards the battery drop is significant decreased.
hachew
bought 4GB RAM 32GB yesterday. seems really fast and battery at 40% after 8 hours use with waze, gps maps, messaging. quite impressed so far. was using nexus 5.
the app drawer grid can be changed to 5 x 5 or smaller but I can't figure out how to do same on the home screen.
can each home page grid also be changed to 5x4 or 5x5? Seems wasted to have such big spacing between the 4 rows apps. thx.
how you manage to get that kind of battery!!!!
my battery drain like damn fast. Cell standby took up a lot of the juice!!! anyone with this problem??
erimin5
If don't need so much raw power i.e. 4GB, the next best buy will be 550ml for its price ratio ?
yusoffb01
My WiFi at home and 3g outside. Using 2 sim card
So far last charge was Friday. And according to this battery will run out tmr 3pm
hachew
ur cell standby is only 2%. Mine is like usually more than half of the total. A bit pissed off and disappointed. now checking out google on what are the possible problem.
yusoffb01
Root your phone (see a few pages back)
Disable Asus apps (have 30+ that can remove )
Install greenify to hibernate apps other than music player and WhatsApp/line
your phone from which telco? or from third party shop?
Lazada oricoms seller. Got at $220 when it came out
yusoffb01
Anyone bought casing online yet? Any recommendations?
Sent from Asus ASUS_Z00AD using GAGT
I have clear casing. Bought for 1.31 SGD from eBay. But looks like seller increased price
http://m.ebay.com.sg/itm/181704883927?_trksid=p3984.m1439.l2649&_mwBanner=1
Also have those casing that that can put cards.
http://www.ebay.com.sg/itm/221751766208?var=520596981387&ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
Weaboo
anyone knows where to get screen protector for this? pretty noob at pasting it so rather buy from physical store
wlbwlb
After root, cannot OTA update right?
If lollipop 5.1 come out for ZF2, can update?
