XiaoMi MiPad
cscs3
heng i think stay away from xiaomi better.
Agreed with you especially now a day many other brand also able to sell at around the same price range with similar or better hardware specification.
arcturuz
Was about to ask the forums whether it is worth buying the Mi Pad as a home device since my laptop died. Saw the comments and it seems like its not worth it?
For me it's still okay for casual web surfing and Facebook.
The screen is quite good quality too.
amazingone
Maybe the Mi Pad 2 that might be coming this year would be better.. Fingers crossed.
tckrto
I using the 64gb version leh and just change the rom to global. So far so good leh except after updating to latest version the wifi sometimes not working. Play games watch movie surf net not much problem leh.
kyleongwl
no tablet, incl ipad, "could" replace laptop unless its for surfing.
At S$299 (wifi), it ok
Pre-loved set at S$210
as mentioned, by some, a Tab S, better display and more accessories, might be worth to consider
yiptw89
New update
MIUI 6.4.3.0(KXFMICB) | Stable
Update summary
System
  • New - Support more countries and areas (Russia etc.) (04-14)
mozaat
I recall someone saying can use mipad like the ndivia shield for streaming game. My gaming rig 760gt so function is supported. But cannot find aps for the game stream to work. Anyone can guide thx
arcturuz
New update
Update summary
System
Updated. Device seems smoother lol.
Edit: after playing around for ard twenty mins the keypad seems stable, no longer disappearing halfway when typing.
eyz
just flash it with CM11 and you'll have no complaint.
caterham7
laptop & tablet quite different, different form factor; also in this case, different OS [windows/mac vs android]
should google around to see mi pad reviews; the mi pad has more issues compared to xiaomi phones
k0g3pAn
yeah i was the one who recommended it.. that goes wayyyyyy long ago since last year August when i got my mipad...
anyway the app used to be called Limelight, now is call moonlight game streaming..
https://play.google.com/store/apps/details?id=com.limelight&hl=en
it function exactly the same as nvidia shield streaming... you need a relatively good router and stable network connection to achieve 60fps.. coupled with a ipega 9023 tablet controller and you get yourself a killer gaming tablet...
taker42
After flashing cm 11, my home button doesn't work like normal. In app, when I press the home button, it doesn't close the app as I expected, instead if I was typing it will just move the cursor to the front.
Did I flash the wrong version?
I tried the 20150327-UNOFFICIAL-mocha and 20150430-UNOFFICIAL-mocha versions. Both didn't work.
And I did wiped and reflash a few times too.
d3n
i just bricked my mipad while trying to flash to CM11 :o
need to bring to xiaomi svc center to reflash already since now can't boot up :(
