Xiaomi Mi 4i
arcturuz
looks like the first 'flash' sale for the mi4i launch is just to create false hype
geckoSG
After heat adjustment in new firmware, phone performance drop in normal battery mode. As I key this message, the keyboard sometimes fails to keep up n display. Maybe I need to disable the auto word suggestion
kyleongwl
New firmware? As in out of the box and OTA which is 6.5.3?
I do feel heat build up is faster than other fon
tckrto
Last night got new firmware. So far from my observation battery drain slower liao. Previously fully charge on stand by over the night drop 15%.After update drop 5%.
Heat seems better but need to confirm again.
arcturuz
i am having this issue with mipad too
when typing in hwz forums, the keypad would randomly disappear
very frustrating
cscs3
Buy and try then sell at $50 loss still makes sense
You means trade in at $50. I Think this is more likely the case. I tried to sell my Redmi at those 2nd hand hand phone shop. They told me no value and not taking in.
Dimitric
Is there a new firmware? I don't see it in the updates.
My take on the phone so far after 1 week:
So far so good no issues with all my apps (apart from not knowing to enable auto start for line). Batt life seems quite good; only lose about 2-3% overnight. It was only slightly heated when I first used the phone while installing all my apps back, after that it seems pretty OK to me.
Some pros as compared to my S4:
1. Much better visibility on screen under sunlight
2. Better batt life with all the same apps (i think partly because its a new phone)
Cons:
1. Still trying to get used to the miui since it can't be disabled
Question: how do I enable multi tab in chrome? I am able to jump from tab to tab when I was using s4 but seems that on mi4i it doesn't allow me to do that
tckrto
The original browser got a "+" that's the function to add tab.
Alexz_Hong
It might be because you have the merge tabs and apps turned on in Chrome's settings. Turn it off and the behaviour should go back to the way you were familiar with.
caterham7
Cons:
FYI, if you are not used to miui, you can install a launcher like Nova Launcher to have the usual android home screen and separate app drawer
exent
Due to current "bugs", you can't install google now launcher or even nova launcher. Just try it out and use for a few hours..
TheHeist
Any feedback of Hearthstone playing experience? Does it lag? While the game is in play, does it disconnect when switched to other apps? Thanks!
