khroness
- Dec 24, 2007
Spam ww with some rends will bring the wotb uptime very fast.
with zodiac ring and full cdr.. you dont need rend anymore.. that's the new snowball ww build
I'd be grateful if they allow to carry my gem of ease to other servers.
u need rcr on your para, though not on your items... the reason is the passive berserker rage where u need to maintain full fury as much as possible for additional 25% dmg..without rcr, you use more fury than u generate, resulting in shorter uptime of berserker rage.
Hmmm viable alternative but currently running rorg and coe.
coe is good on baba?
i tot it was good only on wiz?
wiz is FNR... COE is only for those that is using unity or rorg
Hmmm strangely i use fnr on my monk. Attracted to the 50% damage buff.
iirc the in thing now is in-geom with envious blade for ds build.
only for t6 because in-geom procs require u to kill elites and u actually want to skip elites
GR still FD
Have you tried the snowball build? How is it compared to the other ww builds?with zodiac ring and full cdr.. you dont need rend anymore.. that's the new snowball ww build
yes.. very powerfull and fast clearing trash but rg is slowHave you tried the snowball build? How is it compared to the other ww builds?
Reroll rcr . I stopped pushing now to continued farmingI see thanks. I think I will try push to GR55 with current build then try snowball ww. Get a decent obsidian ring, then reroll stats to cdr zzz... The one thing putting me off, had enough of cdr after playing previous sader builds
