ASUS Zenfone 2
bumdssa
what screen protector are you guys using?
& any good casing you would recommend?
Thanks.
Ye_Rongtian
Thanks.
Using normal tempered glass at any mobile phone shop at $15. If they charge u $30, walk away. Rugged casing can be bought at asus funan at $39.
mach0men
normal one still need to pay $15?
u can get one for less than <$5 on Qoo10 for non-branded.
Sunray69
Hi, which shop in Funan is selling the rugged case? I've been to an ASUS shop at lvl 3 but can't find. Able to let me know which shop in specific and able to post a pic of the case? Thank you.
bumdssa
anybody gotten a 3rd party zenfone 2 flip cover?
i see the ones on qoo10 all complain say the fit is not good.
Arucio
anyone got call issue? the caller at the other end mentioned that my voice is quite soft... but i have already set the volume to max.
Ye_Rongtian
There's only one asus branded shop at funan... it's kept in a display case. Will take pic tomorrow.
Ye_Rongtian
They apply for you... and if they mess up the application process will replace it. U order online probably will reach here smashed (had 3 of my glass screen protectors cracked) and end up refund, wasting your time. It's not like the price is $50 (Saying spigen yes!)
