ONEPlus ONE phone
cheong79
CM12 is better for my case. Touch sensitivity is much better than CM11S, so upgrade is not an issue for me.
I dun want to take risk, as some of us facing issues after upgrade.
You see smoke so definitely there a fire somewhere, and no strong wind = no strong wave on sea.
Happy with current cm11. As i said why fix it when it ain't spoil.
batboyz
Yup, there are always 2 sides of a coin. For my case, I got it better since my touch was not good on CM11S, so the smoke/fire/wind doesn't apply to me.
rVn_mUfC
Cm12.1 is crap. Nfc can't use, frequent reboot,battery drain and apps frequently disappear from home screen like ghost. Think I may gonna switch to oxygen os instead.
highdiver_2000
i have never got my NFC to work, even with cm11s.
How did you do it?
What app did you use?
What do you use it for?
batboyz
Our ezlink is Sony felica I think. Doesn't seem like opo can read our ez link card..
It's not just OPO which can't read ezlink card. Other devices are also unable to read. My HTC One M7 is also unable to read. However, it should be able to read kopitiam card, although I've never tried on my OPO.
shawniiex
Super old ez link can. Dk why they go change. So irritating.
Snokey
thanks guys for the tip on changing the starhub APN to Gee Shwap, hopefully it works!
my OPO just drained from 100% to 60% overnight because of this
