Xiaomi Mi 4i
jmksqjt
updated to 6.5.6, but dono what had changed...
but i realized the phone was really slow & almost hang while i was updating the apps through play store(while the phone was still at 6.5.5 version)...
Sent from Xiaomi MI 4I using GAGT
Z_Dash
Line chat facing issue which message incoming notification does not appears throughout the day till i open the chat.
Any solution for this?
sairio
Maybe it's similar to WhatsApp issue..open the multitasking option and slide your linechat down so that it is locked and will not be killed when you close all apps
auzzuro
How come when i laumch COC it took a long time ? Anyone face the same problem as i ?
tckrto
Yeah I'm impressed with battery life
That's because xiaomi turn off 2 core in balance mode... And I suspect they lower the clock speed in performance mode. First time encounter frame drop in games...
cscs3
This is exacty the same method they used in Redmi 1s to reduce heat and improve battery life. Buy a 1.6G processor in the end only use it as 1.3G. Notmal use is ok. But come to video and game you find the different.
DigDub
the latest update seems to have a good balance between speed and battery life. feels snappy and battery life improved. standby battery life also very impressive.
the rotate bug and battery charge bugs are still present though.
