The Spectacles Thread. - Part 2
GreatKen
i recently gotten a pair of Oakley Crosslink Switch OX3128-0153. realized that the nose piece is wide thus it doesnt fit on my nose xxxx
does service centre able to change the nose piece to narrow and longer ones like OX3150-0156?
How's Crosslink? I heard there are disintegration after prolonged usage.
rainbow99
Those branded eyewear on qoo10 or groupon, any bros have experience if they are authentic? The ratings on qoo10 look good, but pricing a little too good to be true.
ahboy82
A lot of fakes. Dun bother la
Dreaming
hey guys are there any spectacle lenses that helps to protect our eyes from looking at the computer for too long? My workplace the monitor lighting makes my eye feel uncomfortable even after i try to set the setting.
SGsellall
May I know what's the price difference of Crizal 1.6 prevencia for high index (800+ degree) with astig (uncertain) vs Crizal 1.6 prevencia+ transitions..?
jervin88
bro, try out the blue control lenses provided by the many brand of lenses. see which one you like.
jervin88
bro recommend you do 1.67 index minimum la. if can please do 1.74. 1.6 too thick liao, bo swee
Dreaming
brand like crizal and zeiss which is better ?
For crizal - CRIZAL PREVENCIA ?
For Zeiss - I dont know which type of lenses have blue control.
jervin88
both ok la. zeiss is just blue protect lenses. same concept.
main purpose is to reduce ur glare and hope it helps ur eye in future. u try prevencia lo, since the cut off from blue is noticeably more than zeiss. zeiss one more natural, maybe u will still find computer glaring.
DiamondJuice
hey guys, i'm looking for browline spectacles frame, those frames that are thinner or framless at the bottom half of the frame. Preferably bigger and squarish kind, abit of retro and nerdy looking.
I've searched many shops and most of them are selling smaller or rounder version which i didn't like.
Dreaming
what about i also want the glasses to help protect my eyes from UV too? should pick prevencia
jervin88
bro maybe can recommend you viktor and rolf frames
