The Spectacles Thread. - Part 2
jervin88
what about i also want the glasses to help protect my eyes from UV too? should pick prevencia
Bro most lens got uv now. Now technology zai liao haha. Crizal is front and back. Other lenses all is front uv blocking. Is ok one. I think u just decide on which brand of blue control. Uv dun need to worry too much.
For-kel bro, knowledge only la. I wear spec my whole life hahahah.
Sent from Samsung GT-N7105 using GAGT
RyanGiggs11
Hi,
The last pair of specs I made is more than 7-8 years back. I am currently in the market for a new pair.
I read through the last few pages and you guys are talking about crizal. How about Hoya?
And how much does a tag heuer frame cost usually nowasday?
Thanks.
jervin88
Hi,
Thanks.
wow 7-8 years. thats too long. eyecheck every year bro. maybe can try hoya new coating and feedback to us haha.
or maybe even other better ones.
ahboy82
sorry guys maybe this is a little out of topic
but just wanna check for sunglasses, will the uv coating on the lens eventually wear off? mine seems to......
and is it possible to go to those shops and ask them to juz replace the lens??
jonleelk
Yes to your last question.
RyanGiggs11
Ok. I checked the receipt for my frame. Lol. It has been 10 years. But I did change the lens 3-4 years back as the coating came off.
I have always been using Hoya and never try crizal before thus I dont think I am able to make any comparisons.
Is Tag Heuer frame still good?
ahboy82
I recently juz bought n i muz say its the best frame i ever had
Damn light
But pretty costly la. But i wont b changing specs for no reason bah
lunarsong
anyone knows where can i get sports eyewear with presciption?
similar to this:
jervin88
Damn light
so far my experience is dun get those rubber temple one. will wear off easily. just a material disadvantage. stilla good frame. recommend you find titanium frames. good quality ones will last you for several years.
super365
I am considering Crizal Prevencia lens. Hope to hear some experience.
When you wear your spects, do you (wearer) see your lens become purple, if there is light source at top/behind/side of the wearer?
Any other cons of Prevencia ?
Other people will tend to see your lens become blue frequently? Non Prevencia lens look more transparent seems nicer.
Got people said that if there is light source top/behind/side of the wearer, the wearer will see purple because the inside lens side (near eye) also reflect blue rays so wearer see lens become purple, and annoying.
Thanks
super365
Crizal UV and Crizal Easy got any big difference? How much more expensive is crizal UV?
Is the cheapest crizal enough for UV protection?
Crizal got only 3 types correct? Easy, UV, prevencia
jervin88
Thanks
user will cfm see abit yellowish one. then for 3rd person they look at u cfm slight blue/purple reflections at certain angles. cant be avoided. if you like transparent and good perception of colours then not recommended for u
super365
1. Will 3rd person see the prevencia lens a bit yellowish? If yes, yellowish color is look like those normal lens after a few years turn yellowish?
2. In a office (with normal ceiling white lights) will 3rd person see the prevencia lens slight blue/purple reflections at certain angles?
jervin88
ya something like that. under the sun or any lighting can see one la, as long got light = reflection. go down shop see one sample yourself then u will; know
super365
Somehow I think prevencia makes the glasses looks like non coated since 3rd person will always see blue reflections. Those cheap non multicoated lens also have similar relfections except they are non colored. Not sure if anyone have the same thoughts.
jervin88
every multicoat lens give off reflection at certain reflection. prevencia does give off slightly more obvious purple reflection.
thats the purpose of the whole technology of the lens.
it is not advised for all users as some are more particular about their colour perception. might not be suitable for you as well.
u can try the sample and find out that its not like non multicoat lens as they do not reflect light into your eyes like non multicoat lens.
its only seen on the outer appearance. what u see is just like multicoat lens, comfortable without much reflection in ur eyes.
cheap non multicoat makes wearer feel uncomfortable as they reflect light into the eyes.
wiz
Damn light
ahboy82, how much you paid for yours? and where? pm me if it is not convenient to disclose.
In the market to replace and looking at Tag as well. Thanks
ahboy82
I buy 2 pairs both at kwon shin bras basah. Limited selection though but i like the service there as they r not pushy unlike many other stores
Iirc one is at 600+, another 700+. Price inclusive of crizal lens. Doubt i b changing specs in the next 3-5 yrs as these 2 pair are the best i ever gotten.
Before i took the plunge i tried swiss flex. But didnt work out for me as they keep sliding down :(
