LG G4
Bryson
She never complain of any issue after pasting leh. I am assuming, it's a clear sp just like you were to take a photo of a fish in an aquarium tank at close range. Guessing the sensor should be intelligent enough to distinguish that.. Besides, it's a $2 investment/experiment however one may wish to describe it.. :)
Edit: Another way, you could conduct this experiment is by taking a photo with your home window open and same exact shot with the window closed. Or if you have a clear cellophane plastic lying at home cover the sensor and take a shot with and without. See if there is any notable difference.
Sent from coin operated public phone using GAGT
I think I'll try her method of using a cut out screen protector. Also, I tried to test the focusing speed with the laser and covering the laser. Speed is just slightly tiny bit slower when I covered the laser..
Sent from LGE LG-H815 using GAGT
St00ky
just got my G4 pasted with TGSP from P2O.... the full screen one that covers everything except the speaker. didn't notice any problems with proximity sensor or touch screen sensitivity. only problem is the bubbles at the bottom of the phone beside the LG logo :(
MZeee18
I'm using the Spigen Film SP. I scared use glass got bubbles. Later my OCD kicks in
waterballoon
so strange.. why P20 mobile got such bad service. last time they ignored my messages/questions, and realized they tend to paste SP with bubbles and not help customers with it :s11:
chehjin
me... if u get the one that cover everything except the speakers.. it will affect the screen sensitivity and proximity sensor..
anyway to re calibrate the proximity sensor? its causing the phone to not response for a while after the phone call is hung up
doki81
Thanks! I didn't know that, I kept using the quick memo thingy
some people find this is very hard to do. quick memo is easier...you can set the quick memo on the bottom home menu there and no need pull down notification~
yknyong1
I realise you can disable Google+ app under Apps in the settings to get great battery life. It actually drains the battery by automatically running after you use the camera.
TitanSmall
Not that i know off. That's why i changed my SP. I realise under strong lights (directly under the sun) no issue.
