- Mar 9, 2004
B&H in SLS. You walk in ask lo.
If the card gets too hot, make sure u frost it!!!
Btw that fan looks alot like a Scythe GT 3000rpm version or so![]()
is fury x supposed to be faster than titan x ?
Both insider source and ocn confirms it is coolermaster fan.
Since OCN posted now I leak liao lol.
Should be somewhat the same lah (+ some/- some), same clocks vs clocks.
So it's back to how much Fury X can OC and achieve a desirable temps?
Just imagine the same default clock Fury X is on air-cooled? Good luck ..... if not why AMD have to resort to rad to lower the temps in the first place? to show it's power efficiency and awesomeness? lol
If 4k > res with everything all turn on, Fury X get drown faster than Titan X![]()
AMD own marketing charts
Fury X VS 980Ti
Royfrosty, care to slide the core clocks moderately and run some stability before the drivers crashes? if you have the time
Just want to have a feel what's the OC potential and rad temps of the Fury X![]()
length of gpu ?
