[GPU Review] Sapphire AMD r9 Fury X on the rise!
soufigo
will a single fury x be better than a pair of 780ti? for 5760x1080 triple monitor setup.
garfield82
If the card gets too hot, make sure u frost it!!! :D
Btw that fan looks alot like a Scythe GT 3000rpm version or so :eek:
Mikiberry
Both insider source and ocn confirms it is coolermaster fan.
Since OCN posted now I leak liao lol.
maylyn
is fury x supposed to be faster than titan x ?
Should be somewhat the same lah (+ some/- some), same clocks vs clocks.
So it's back to how much Fury X can OC and achieve a desirable temps?
Just imagine the same default clock Fury X is on air-cooled? Good luck ..... if not why AMD have to resort to rad to lower the temps in the first place? to show it's power efficiency and awesomeness? lol
If 4k > res with everything all turn on, Fury X get drown faster than Titan X :s13: ;)
AMD own marketing charts
Fury X VS 980Ti
royfrosty
Fury X VS 980Ti
Ehh so far quite true leh the chart provided by AMD. 4k results are true.
Uploading Shadow of Mordor, giving both 1440p and 4k res benchmark in 10mins.
royfrosty
And yes the box got a printing error.
Here are some of the Fury X temps and stuffs after hitting SoM on 4k. Yes it have not saturated 4gb.
Was running on 3.8gb with everything maxed out.
maylyn
Royfrosty, care to slide the core clocks moderately and run some stability before the drivers crashes? if you have the time ;)
Just want to have a feel what's the OC potential and rad temps of the Fury X :D
royfrosty
Can. But not tonight. Sorry ar. Im trying my best.
royfrosty
And here is my proof!
Finally AMD speaks the truth!
1440p settings
1440p benchmark scores (Totally no kick)
4k settings
4k benchmark scores
royfrosty
Hmm lets see what other games i can tackle against the AMD chart provided.
And was thinking of something like is there any games with virtual 4k just like SoM to test it out.
Vulpix
Moderator
Moderator
If I already got a CPU cooler mounted on my rear of case, how to mount this ah? :(
