[GPU Review] Sapphire AMD r9 Fury X on the rise!
royfrosty
If I already got a CPU cooler mounted on my rear of case, how to mount this ah? :(
Ok the tubing is about 40cm. So its either you mount your CPU cooler on top or at the front and GPU at the rear. Whichever is convenient for you.
royfrosty
Heaven Benchmark 1440p benchmark full settings
Ok to further conclude, it will not go above 60deg on full load.
The GT fan really damn quiet on default settings. Radiator feels warm but touchable.
Mikiberry
Roy ~ how is the operating temps like? AIO cfm have alot of OC headroom.
Mikiberry
Yet to test OC.
Operating temps gaming load around 57deg to 58deg, idle 37deg min, 60deg max on full load.
Omg lol ~ imba card for 1440p - Single card solution for all your gaming needs lol. low operating temps. If custom cooling in SFF cfm shiok. I think your 900D comes in the temps will be overkill lol.
avsquare
Dump your Titan X go Fury X CF? :s13:
maylyn
That's will AMD Fury Nano's arena :D
I'm more intrigued about this AMD Fury Nano than it's bigger brother :)
Question is @ TDP 175W, how hot will be it or AMD is able to tame this beast? :D
Guess all will be reveal in due time ;)
royfrosty
Kinda stress relieving when seeing the gpu turn on and running. Heres a pic of it.
Quite fascinated by the loading LED up and down lol.
enenyi
Ok. On par over 980ti stock. Not Giga.
Not much difference, but the Max FPS went upwards.
Able to clock it up to hit Giga base clock speeds and run SoM again? Coz the last thing u wan in comparison between brands is the clock speeds interfering with the results.
This is getting interesting. FuryX doing a 980Ti at a cheaper price.
