sharepoint2014
- Feb 8, 2015
no wonder...
I am using 7002 (in middle of the living room). My wireless connection will very weak when I am in the master room (6M away from 7002) without the door closed. Please advise, if I request Singtel to change to 7003 will help the wireless connection? Thanks in advance.
no i doubt wireless coverage will improve since the only difference is wireless ac on 7003.
you might want to explore on changing the position or location of the router so that you will have a better coverage. a higher position of the router helps..
Currently on 300mbps plan and miotv with the 7002 router.
Considering to upgrade this 7002 to a ac router. Anyone replace their 7002 with 7003 successfully?
Call singtel and the cso told me to get a 3rd party ac router instead. Is there any 3rd party router that is able to link the miotv service?
Go to router admin page and enable Samba server. If you don't know how to do it, check up post #52 in this thread. But instead of looking for Device Status, look up Samba Server under Advance Setting.I see my 7002 router behind got USB slot, does that mean I can plug in my ext harddisk into it and all my pcs and access to it?try looking but can't find an answer,anyone can help thx
Hi all,
I noticed that the Aztech 7002 does not have the DDNS function on the router settings page. Any one knows a way to get around this problem?
I need the DDNS function to make sure that the external IP is updated automatically when the modem router's external IP is updated.
Hi, singtel just came to setup my 300mbps wireless. Everything working except my mio TV box. Try rebooting all device many times but still same. Anything i should look out for? Currently i just connect the ethernet cable to ethernet port 2 of Aztech router
Strange la. They should have tested the Tv too. Just need to call 1688 and ask them to refresh your line and it should be ok. Otherwise request to replace the set top box.
anyone tried calling singtel to disable vlan on their side?
i'm not using telephone and mio tv.
can i do that so i can get a TP link Archer C7 to replace the crappy 7002.
