Depends how you look at it. Being a LG G Flex 2 32GB/2GB ($449 local) owner I say it's better deal than oneplus 2
My view is OP2 more ram for future Android, but looking at all the OP1 users going crazy over OP2, I think majority will change the phone in a year. Only OP2 drool factory for me is the OV13860 1/2.6" 13MP sensor. I have IUNI U2 that uses OV16825 so I can guess how good OV13860 really is when uses correctly.
In term of design GF2 is better, screen display likely OP2 wins. Storage GF2 support microSD. OP2 battery bigger, GF2 has quick charge. Selfie cam goes to OP2.
Firmware wise GF2 had used the past 1/2 year to improve, from overheating issue to now almost similar daily operating temperature as OP2 using just firmware updates. OP2 had the privilege of SD810 v2.1 and time to improve the hardware. (My statement is based on report of OP2 running antutu test and tested for max 37C. While I tested GF2 with lastest firmware 38C with lowest brightness and 37.5C with max brightness.)
Being almost $100 cheaper with local warranty, I personally think GF2 is a better buy.
