Upgrading to Windows 10
muddle
Har? Like that one ah? :s22:
You use ProduKey to check also?
I used produkey and belarc advisor both also show same key. Just to confirm, there it no OEM wording anywhere in my 8.1 pro product id. Same goes for the win 10.
Ohayo!
Have you tried a proper clean install of the windows 10 drivers with something like the display driver uninstaller from guru3d? I had random fps drops after upgrade and that fixed it for me at least
games don't seems to work well on win10 at the moment.
tried uninstalling. but when i updated my drivers they wiped my NVIDIA control panel settings prevoiusly.
now i fully uninstall using some DDU only have occassional stutter.
Techno Pride
Windows 10 is OK at home.
I have to use Server 2012 and Server 2012 R2 (Win 8 and Win 8.1) almost every day. The start screen is...zzz.
Techno Pride
Firefox still berri goot to use but they forced default to off flash. I prefer flash over html5. Beedio ish alot clear...
For YouTube, there should be a Firefox add-on to force Adobe Flash plugin. Google Firefox YouTube flash.
jtjt00
Clean install is always less issues as compared to update.
IlovePCW-ing
That is strange. The revert to previous version is buried in the settings and need user confirmation. I will be pissed if win 10 suddenly auto reverted back to win 8. Need to spend time to upgrade again.
nvm la. as long as can use again can already.
better than stuck on the windows 10 logo
xiaowhois
will data be erased for rollback~?
very troublesome to reinstall again, last time I installed win8 and rollback all my other software gone~
You never know what will happen~ backup or else data gone
noobiee
wah quite surprise this thread will hit 30 pages
so many unhappy windows 10 users ah haha
Koenig168
It's Windows, sure to have teething problems. Actually, Win 10 turned out to be more stable on launch than I expected.
The spyware was unexpected and unwelcome though.
Koenig168
It might surprise many to know that Windows 10 has not been officially launched yet.
Koenig168
That will officially be like...2 years of beta testing?
Hopefully, shorter. I would like to get rid of my backup OS. (I have Win 8.1 Pro installed as a backup in one of my HDD partitions.)
VoodooKing
Are your Win 7/8 retail or OEM?
All 3 of my Win 10 Pros upgraded from OEM Win 8.1 Pro have the same product key VK7JG-NPHTM-C97JM-9MPGT-3V66T.
Paiseh paiseh, my brother's one is Home version. My pro version key is as above.
