[PSA] Z170 chipset may affect Windows 7 users
muddle
One big shock will be for Windows 7 users. By default, the Z170 chipset and BIOS will not support full USB 2.0 Enhanced Host Controller (EHCI) mode. This means that for a number of circumstances, USB devices will not work unless an XHCI environment in play.
In our testing, this means that in order to install Windows 7 you need to do the following:
Navigate to BIOS
Enable ‘Windows 7 Installation’ or ‘EHCI mode’, Save and Exit.
Have your Windows 7 image on an optical disk. USB sticks will not work!
Install the OS as normal via the optical media. Install OS drivers/USB 3.0 drivers.
Disable the BIOS option.
This is done for a couple of reasons. Firstly, it helps reduce the size of the BIOS for more customization. It also aids moving users to AHCI capable operating system installations. For everyone else, it is a bit of a headache. As far as we can tell, almost all motherboard manufacturers (at least the Tier-1s) will have this option in the BIOS to enable Windows 7 installation.
Taken from http://www.anandtech.com/show/9485/intel-skylake-z170-motherboards-asrock-asus-gigabyte-msi-ecs-evga-supermicro
muddle
Will be difficult for people without dvd drive.
Yes. According to wcftech, you might even need to use ps2 mouse and keyboards during installation since the usb ports are not detected
A7997A
Navigate to BIOS
Taken from http://www.anandtech.com/show/9485/...-asrock-asus-gigabyte-msi-ecs-evga-supermicro
It would seems like ASRock already has a solution to this issue,
and I would be surprise if no one else follows up with their alternative.
Goodshot
Then just install win10 sua , but anyway i always keep a ps2 mouse in my home
escksu
You may not be able to install win10. Imagine those who has win7. They have to install win7 and upgrade to win10 first then can do clean installation of win10.
trenzterra
My thoughts exactly. Lucky I have Win8 to upgrade from haha.
