ZacharyA
- Apr 11, 2010
Lets bring another option to the table....ICAEW.
if you guys have been following SQP, you will know what it is modeled to ACA (ICAEW). The reason for singapore to go for chartered against certified title for our country is strategic, to be in CAWorldwide (go google) for intl recognition. ICAEW dont require degree, in fact a level can get in, acc diplomas get cert level exemptions, degrees get 7-12 exemptions depending on uni. ACCA and CPA gets up to 12 also. BPP University masters get 15 papers.....etc
The point is ACA and CA Singapore will VERY VERY VERY likely have full mutual agreement, which means there is a way to get CA singapore without degree. WHY the loophole? because ICAEW is working with Singapore Poly and acc diploma grads get whole lot of exemptions into the programme. so here's the backdoor route. (secrets revealed!!!!!!)
So ACCA still have hope to get CA Singapore. To top up with 3 more papers to get the coveted ACA title which will give you CA Singapore also.
BAMP! 3 "top" titles. THIS is how you should be planning your paper chase.![]()
agree and respect the prestige of ACA by ICAEW but to obtain ACCA you will need about 2-3yrs, and then subsequently to be converted over to ACA takes another 5 years post ACCA + bridging / additional mods to be taken... At the same time, not sure if one is required to be with an ATE by then to fulfill all conditions to be converted. Need some ACAs to advise more info on this... and by then you will be able to obtain CA (singapore) upon full reciprocal arrangement by both bodies...
IMO its too long a route compared to degree -> SQP -> CA(Singapore) which is certain and confirmed route for now.
Btw, ICAEW annual membership fee is $800/year right?
