The Samsung Galaxy Note 5 Thread
ZenTape
Hello, New Note 5 user here. :)
So excited.. Now updating the phone ^^
Edit - ****.. I forgot to activate the 100gb for onedrive and then did a factory restart after the firmware update.. Wonder if the 100gb activation will still be there .. :(
ZenTape
Btw, after a factory reset, I was prompted to install samsung Knox.. Is it advisable to do so? (I dont think I will be rooting though).
kEvinErd
Does the latest update today solve the slow response issue when waking the phone after some time of idling?
Edit: No, it doesn't solve the slow wakeup issue..
DaRRenLieW
I did the same thing. I do a clean wipe after I got the phone but the one drive prompt me when I restart the phone.
DaRRenLieW
Slow issue when you press the home or the power button ? If is the home button then might be the way you press. Try to press central
Lobaba
I beg to differ. My Fiio X5 + Fiio E12 ... still sounds better than my n5 + Fiio E12 ^^
lol yea, cowon still better, N5 accents the bass and is still kinda muddy and messy whereas cowon separation is much better
Alexz_Hong
After standing for half a day playing with note5 and edge+. Finally decided on 64gb black note5. Irresistable. Hope i make the right choice
To me the note 5 is a much better phone than edge+. The s-pen alone is enough. Even both same price I'll still choose note 5. It has a few annoying issue like the slow to wake mentioned earlier, some weird camera quirk which opts for higher than needed exposure when tap to focus, and the battery life could be a bit better if you ask me. But other than that, it's a pretty great phone. Just see the reviews around.
lxb_70
Think s6 edge + more ex than n5 leh
Sent from the dark side of the moon using GAGT
kEvinErd
I'm pretty satisfied with the battery given that it's only 3000mah! Easily 4hrs screen time for my usage, more than enough in a single day for me!
Alkamizt
Don't worry. It will still be there. In fact it is a menu entry under the settings window of OneDrive.
Samfreak
I finally succumbed and upgraded from S4 to N5 (Gold 64gb) this evening. Decided the Black is just too dark after spending more time at the Experience store with both colours.
I know I will regret when/if Samsung introduces the Silver Platinum some time down the road.
Transfering data using Smart Switch now!
technolust
Just get a titanium silver case lor. Problem solved :)
ecneret_eel
well, gold is gorgeous, so no worries, I believe they both have their unique appeal.
Sent from LGE LG-D855 using GAGT
