Huge mesh seat space complete with headrest, adjustable armrest and back support, on steel legs and frame.
Gotten it for under $200...
steady la mod!!!!!!!!!!
Courts selling identical chair @ $129 called "GT racer". Actually quite comfortable for semi-slouch position and all mesh + plastic is great for non-AC environments
http://list.qoo10.sg/item/DX-RACER-MESH-CHAIR-TABLE-OFFICE/424611921
Wah last warning sia lol. This one dare to use the word DX Racer lol.
Anyway I eyeing on Secretlab throne chair. I really love their back rest.
Been using for 2 years, so far no issue.Is there any squeaking sound? Mine will start to squeak and the hydraulic lift mechanism fail to stop the chair from slowly sinking. But mine is the cheapo sub $100.
Will this spin and rotate dynamically?
i own an Ergohuman V2. nv try the HM bcos exceeded my budget. I would say the chair elevated my backpains from those plastic chairs. Helps that it is very adjustable too. slight regret is choosing the bigger sized one as arms sometimes cant rest properly on armrest. if possible, i would suggest u ask them if can include the extended footrest and get it together with your chair. used for 3 years plus and still very sturdy with no signs of defects. mine is the fully black mesh model.
I tested the Ergohuman at Apres, very solid chair. Can I check where you got yours and what is the pricing?
i got it at Apres too. I went down during lunch time to test the chair. Was quite impressed with the showroom and the number of chairs they have. Also tested almost all before i decided on this. I made an appointment before i went down though and was quite surprised the MD personally briefed me on how to choose a good ergonomics chair. Made a deposit on the spot. Pricing was 700+ (can't recall exact figure). Tink the chair have 10 years warranty too. Btw, the mesh doesn't sag after prolonged usage.
