realized that the brightness slider tend to missing at times. anyone with me?
When the phone is low on battery, the slider will be hidden
imagine would I still admire the phone if the built is plastic?
Honestly, the battery life is better than iPhone 6plus. (My gf uses that). And now she is in love with my note 5, especially for the camera and s-pen.. this s-pen really does enhance the overall experience a lot, let alone productivity. I'm a heavier user than her and my fone last longer. Plus there is fast charging, both wired and wireless.. Haha. And not to mention, the screen is super nice..
sorry I used to come from Apple some years back.. and I truly never turn back to ios.. and don't miss it.. in my daily life I come into contact with both apple and android, and I just like android more for the freedom and customization.. I use both macbook and PC at work for different assignments.
Anyway, I'm not a fan boy or what, but will go for whatever suits my usage and whichever is better in terms of battery life, customization, camera, and especially productivity... and I never regret one bit switching to android from ios..
Just sharing my 2 cents..![]()
iOS so jialiat ah?? In fact, I'm thinking to get the upcoming iPhone 6s to try since I have been with Android for a very long time and starting to get bored of it. I don't customized at all. Using phones as they are right out of the box. Even with current Note 4, I'm not having any bad experiences with the Touchwiz while lots are commenting that Touchwiz is bad.
Anyway, I will look at the pricing again by the time when I'm eligible to recontract. If the pricing are close between Note 5 and iPhone 6s offered by telcos, most probably I will try an iPhone - since both Note 5 and iPhone are so similar and without removal battery and microSD.
Was using zooper widget previously in my z1 days. But it seems to drain my battery quite a bit. So after using awhile, I have uninstalled and didn't use it after switched over to Note4.My note 5 restarted by itself 3 times ytd when I was setting up zooper widget. Culling some apps today.
Sent from my cat messengers using GAGT
Wah, traitor ! :0
Funny cause my company issues us iPhone for work but I never liked it for its user unfriendly interface (Need many clicks to get to where iwant)
My backup phone is usually android. Daily drivers very between blackberry and windows 10 mobile.![]()
i change from note 3 last year to ip6 plus, alot thing i cannot do on ip6+ so i switch back note 4 This jan, now changing to note 5![]()
i installed the latest update and cleared cache from recovery. see if it helps. for now its okay.
You know, I really feel it's a shame many Note users don't bother to learn their S-Pen, some never even take out before on their phone. It takes about an hour to practice and get used to it, and it will only increase your productivity at work or other real life stuff.
The S-Pen is seriously one of the best thing so far on a phone, so far no other competitor bother to have a good accurate pen. Tested the Note 5 at the store, it's even more accurate and responsive compared to the Note 3.
I've done so many awesome things with the S-Pen, like circle something on google map screenshot then whatsapp to friend, write some text on it, and it's only the tip of the iceberg.
How do u clear cache ?
