sacredrays
- Feb 1, 2009
when you bought it? so now lowered price liao? (600+?) tempting sia...
I got the md s name card. Very earnest fellow. I think I will buy from him lol. The comfort is better than Aeron in my opinion as the lumbar support is solid.
yup agree. u can adjust the lumbar support height to suit ur lumbar position. works well when u decline the chair too. i use the chair as it is with no other support/cushion and can sit for few hours per session without any pain/discomfort.
additional info. iirc, think the price is inclusive of delivery and can do COD. they will deliver to you wrapped in plastic protectors and fully assembled. just roll into your room and use. I was late for around 15 mins and told my brother to pay them first but they very kindly waited until i am back and inspect the chair before they left. not trying to promote them or anything but the overall process and experience was very pleasant.
will try HM when this chair fails or cant be used. heard good reviews of it too.
I've tried the Ergo and HM Aeon.
End up I bought the MARKUS Swivel chair from IKEA for $399.
Price has dropped to $299.
Got 2 sets.
Lumbar support and good for big size people.
Cheap and good.
By lumbar support, I mean this.
The Aeron has two types of lumbar support - the horizontal type which is useless (in my opinion) and the butterfly-shaped one in the above pic.
While I can't comment on the other chairs in the OP, I have used the Aeron for years and have two of these at home.
Got 2 sets.
Cheap and good.
I just bought the Ergohuman V2 like 2-3 months ago. Total pricing inclusive of delivery and assemble ($609/- [includes GST]). *This is just the default full mesh chair itself without the leg rest.* I was told that V1 and V2 had the same pricing whereas V2 is the newer model.
If you had compare their "V2" to the original V2 as introduced on the website, you will noticed a few differences.
1) Handle bar is different (same old V1 plastic handle)
2) Black plastic cover under seat (same plastic cover instead of revealed metal parts)
3) The seat adjustments (Using 3 in 1 trigger instead of 3 individual controls)
4) The tension control is turning knob instead of crank turning
Basically I would that the model feels like V1 plus instead of V2. I think I also read somewhere that says that the real V2 version is not release in SEA.
Anyway, I tested the chair and feel that lumbar support was there, the mesh seat is quite comfortable. The chair was much much cooler than my previous leather chair.
Overall, I like the chair but It does makes some noise if you keep shifting it around.
P.S. This is the most expensive chair I've owned so far, as I've not tried others (like Herman Miller or similar expensive brand), I was not able to compare the effectiveness of the ergonomic feature of such chair. Except that it is way better than the previous $300+ I used to have.
You can try it out at the showroom, Apres No.9 Harrison Road #06-01 Singapore 369651. Tel: 67410009
I bought a similar chair to the IKEA MARKUS, but from vhive
after 1 year+, the back mesh will start to sag since there is no physical support.
just FYI, and hope your chair can last longer than mine
I tried the hm aeron for a good 30 mins surfing and sitting on the chair. The lumbar support to me is close to non-existing. Should I be changing to posture fit it will be additional cost. While the chair is indeed good, I find ergo human more comfortable and adjustable. In the end buying the ergohuman from apres lol.
When I am free I will probably head down to china square and test out the japanese okamura contessa
Haiyo ... just hoot the HM Areon lah
Don't even need to think so much![]()
