rharish_21
- Sep 11, 2004
Can you guys install myTransport Singapore? it says device is not compatible.. I guess its due to the different DPI
That's good to know. A mini review from an audiophile.Thanks.
I am no audiophile but i do enjoy listening music on e note 5.. Especially when it can be customised based on my hearing that can be setup via the "Adapt Sound" function.
End of day 4 of owning this incredible device. And I dropped it , naked, for the first time this morning. Scratches on the corner now
Finally decided to order the Verus Crystal light silver cover. Hope it arrives quick!
Using nova. Feels the same as touchwiz. But I only used tw for 2 days so hard to benchmark accurately..More like me every morning, "need more sleep" wahahaah
anyone got load google launcher or nova on the Note 5. Is there any performance improvement?
If the price is right then I won't mind. No worries on pic usage. Meant to share it with everyone angwayhello guys, firstly sorry to skaade for using your photo.. Check out this kickstarter project. I am quite worried about the screen protector issue on the note 5, in particular the haloing.
https://www.kickstarter.com/projects/451137703/metearmor/comments
They managed to prove the haloing effect is non-existent on their product.
Not too sure if they are a hoax on the quality but just a heads up for the fellow note 5 users out there![]()
Careful guys, if insert S-Pen wrong way will damage the device.
Here's the video:
https://s-media-cache-ak0.pinimg.com/736x/1b/f4/67/1bf467de0df32661c90bdb7651f64aa1.jpgCareful guys, if insert S-Pen wrong way will damage the device.
Here's the video:
Same issue I had with nexus6 too. They too lazy to expand support.Can you guys install myTransport Singapore? it says device is not compatible.. I guess its due to the different DPI
When one lets kids handle a thousand dollar device without supervision, one has to be mentally prepared to write-off the device...Such dumb actions may happen if you let kids handle it.
Note4 ok. Not sure about Note5.Can you guys install myTransport Singapore? it says device is not compatible.. I guess its due to the different DPI
**** mine broke accidently fiddling around and exactly as described happened...
Any of you also same issue any quick fix or any Samsung fix for this?
Probabaly heading down to service centre for this. If they dun replace or charge for fixing I think I'm gonna throw a fit there...
There is absolutely no resistance when you put it in the other way so you won't know if anything went wrong.
Sent from Samsung SM-N920I using GAGT
oh my God only an idiot will insert the S-Pen the other way around @_@
Zooper seems better now. Using it and no issues with battery drain. So far so good but I just have one clock widget. But that clock widget also displays contextual info where the last line changes with time of day (morning and night shows up differently):
Sent from my cat messengers using GAGT
Bro, any idea what is the left/right arrow icon at the top panel ah? It appears on my wife's but not on mine... and I cant find ways to turn it off also...
Like I have said earlier, the icon will only disappear after you have asked Telco to deactivate the service. You cannot disable VoLTE via phone settings. The icon will still be there if you only "disable" from phone settings.
VoLTE uses your 4G data. But it will not use up much data. Very very small data use as your call will not use a lot of data. You will use more data when surfing the web than when calling.
Note that VoLTE will only work if the person you are calling is also using VoLTE. Otherwise, the call will drop to 3G. For example, you are calling someone's mobile number and that person has VoLTE, then the call will be using 4G. If you are calling someone's office number and the phone is not a VoLTE-enabled phone, then your call will not use 4G but will switch to use 3G instead.
VoLTE, because it uses 4G, will have faster connection. You will dial through faster compared to non-VoLTE calls. The waiting time to hear the dial tone will be faster (almost instantaneous) and you will have better clarity over your calls.
I am not an expert at the call technology, just my experience from using VoLTE. Apology if there are any wrong information being presented.
