The Samsung Galaxy Note 5 Thread
EldonChew
Anyone know if m1 got
EldonChew
She using note 4..so if the other phone don't support it will just not connect? A bit Kuku right.. Hahha
Note 4 not supported (by M1)
VoLTE only works with the following phones on M1:
iPhone 6
iPhone 6 Plus
Samsung Galaxy S6
Samsung Galaxy S6 edge
Samsung GALAXY Note 5
Samsung Galaxy S6 edge+
And hor, your wife must be on M1 network also for it to work
I think just normal call will do.. no need press HD Call
When you call someone it will check if the recipient is on M1 network and if the device is supported
If it's not then it will call normally with 3G
kEvinErd
I am having issues for using the screen capture via home + power button. Using swipe is easier. Anyone can enlighten me? I never had problem with home + power button but on note5 I had tried so many to me but only manage to successfully did 4-5 time only
Sent from Samsung GALAXY Note5 using GAGT
On the Note 5, there's an even easier way to do screen capture and a lot more better to do it this way - Using the Spen and then select Screen Write. This way, you can do Scroll Capture too.
greddy88
mind sharing the seller ID, I wanna check it out wahahaha
Sent from LGE LG-D855 using GAGT
if i'm not wrong, there are only 2 local retailers on qoo10 selling note5.
both should be reliable and priced the same.
so what i did was to get the discount coupons (at first i was able to apply the $10), then upon checkout, there came another option to apply at the cart.. so i tried the $5 one.. and it somehow worked.
so.. -$15 off the already published price from $915.
and then use visa to pay for another 6% off..those frequent the credit card section will know which one for online purchases :D
Momentumm
I have decided to sell my note 5 lol. I think I wanna go back to iOS. Prefer it simpler. hahaha.
RobVanDam
Broken SPEN Detector Issues
Hi guys as a follow up to my other post on broken SPEN detector follow up can check it out here in case you have the same thing happening to you.
Meanwhile have still been reading up on the issues causing this while waiting for Samsung to get back to me and stumbled upon this interesting article.
Article from 9to5 Google at here
The comments are pretty obvious, and quite constructive as well :s12:
VacheronLim
mind sharing which coupon was used? item is classified as "time sale/daily sale/Q chance" so the standard cart coupon cannot be used i believe?
DaRRenLieW
I still find it weird why the screen capture method (home+power) feel not so smooth compare to last time my note 3/note edge Era. Hmm any bro felt the same way?
ZenTape
Hhmm it is fine for me. Also coming from Note 3, I still do the same palm swipe with no problem everytime i screenshot. Used to the gesture liao haha. So far it works smoothly for me.
Actually I rem on note 3 can set it up so that everytime I use palm to do screenshot, the screen write or edit function automatically activates immediately. But now dunno how to set that up on note 5..
Chipero
Can buy a 3m cable.. Can use anywhere.. The irony of wireless charging is the phone needs to be "attached" to the charging pad and u can't use it lol
3M cable too leh che lah ....
nowadays have portable wireless chargers ... if really want to use it while charging ... use a rubber band loh ^^
I am using a portable wireless charger from Sony
