The Samsung Galaxy Note 5 Thread
ZenTape
All buttons fully accessible. Damn sleek. Perfect cover for me because I don't drop my phone ever ^^
Wah nice case.. Wonder if this is the back casing in the redemption letter from telco for note5 purchases.
Anyway just gotten my Verus High Pro SHield.. Hhmm... Added alot of bulk and some weight to the phone.. :(
Omnia1
Understand your pt bro but I'm using note 5 and my VoLTE doesn't work also. When I call my wife on note 4 and m1 it doesn't drop to 3g it just doesn't connect.
Any number I can test VoLTE on? Perhaps 1627? Lol
Any server settings etc I must input?
Encountered something similar when I first used the S6 Edge on M1's network. Was wondering why I had such a difficult time connecting on outgoing calls. I switched off VoLTE and immediately all calls were connecting as per normal. Have not switched on VoLTE since. Not sure whether anything has changed.
Sent from Sony SGP621 using GAGT
WhiteHunter
yup that is the back casing in the redemption letter but can only collect next week.
TrueB1ue
so fast they don give free wireless charging already.
Why huh?
Where still got give one huh?
EldonChew
So that we don't get restricted by how long the cable is ^^
But don't the phone have to be on the charging pad itself to charge?
Isn't using wire better since you can use it while charging?
Using wire also charges twice as fast(1 hour faster) :s11:
Huh? So now you can't make any outgoing calls(to those not on M1 VoLTE)?
should you drop it, those 4 corners will be the first to hit the ground.
He's probably talking about the bezels getting scratched up.
Chipero
Is it only me or are the sides, top and bottom not protected? Only the 4 corners/edges?
Yes ... only 4 corners/edges protected ... its damn sleek ... i like because it doesn't add bulk and weight to the phone ^^
Chipero
if you have a 3M cable attached to the portable charger and to your phone ... u will have a lot of cable dangling everywhere ... outside drinking coffee etc ... then if u have a short cable attached to the portable charger, you have to hold the huge charger + phone and listen to a call ?
Wireless still better ... when no calls or messages ... i just leave it to charge ...
Anyway, I am talking about being outside lah ...
At home I am using the below to charge my phone :
