Delicièux Treats
- Aug 31, 2015
there is one name jhonny tailoring at bendemeer market
disappointed with Lai En tailor for pants wise. Went to tailor a white pants and the material turns out to be old and yellow stained. Most likely will not patronize again.
Any other recommendations on pants tailor ?
Did the fabric turn out not to be the same as what you chose from the swatch?
Did you ask why it was so?
.Was the finished product delivered different from the fabric chosen?
Yes, she told me that the color is due to chalk coloring but it doesnt seems so after washing.
The fabric is the same but probably the material wasn't used for quite some time and it turned yellow.
You know when you did not wear a white shirt for a long time, it will turn into yellowish color.
Disappointed. Need you guys suggestion on other tailor shops.
Sze Sze... Don't know why you would get the impression that Lai En is the place to go for pants..Yes, she told me that the color is due to chalk coloring but it doesnt seems so after washing.
U wanna try soaking it in bleach, then wash with Dynamo Complete (for that extra whitening power) before bring back to them?
Did one shirt and one pant. The shirt was pretty okay but it's abit translucent. I guess Lai En is suitable for shirt tailor than pants.
I heard quite a number of negative reviews on Sze Sze. Not sure if i will try them out. Any other suggestion ?
How about grand city and xin en ? Are they good in suit and pants tailor?
Sent from the exploded Death Star using GAGT
Wow...didn't know can be that bad.The fabric is the same but probably the material wasn't used for quite some time and it turned yellow.
Haha, my first thought too!White pants!?!?!? U doing walk about and rally?
Don't know why you would get the impression that Sze Sze is the place to go for pants..
Have u done any with Sze Sze?
Whats ur budget again lol?
Can try the new fella Este Bartin, think they having promo pants @68
If want gpgt i posted mine couple pages back.
But if you really die die dont want any potential hassles, suggest just pay up and visit the higher tier playas
