The Samsung Galaxy Note 5 Thread
Sinkie
Updated 2 hrs ago. So far so good. Fingers crossed.
sigh, same problem when i use it with swiftkey.. it hangs awhile (maybe 5second) when trying to load the prediction. i even tried to load samsung keyboard during the hang, but no prediction from samsung keyboard either.
when it is awaken in deep sleep, the phone doesnt unlock with pattern recognition, must wait awhile too
rockdjlow
I guess you can do a full factory reset on the phone and if it doesn't work last will be Samsung service centre?
ArsenalGear
Anyone encountered a green vertical line appearing on the screen once in a while? Wonder if it is a hardware or software problem.
Sinkie
I'm facing the same problem when I'm using note 3 too
Maybe the size of my whatsapp is big
Alkamizt
The problem with the sleeping beauty issue is that it is unpredictably difficult to reproduce on demand. So how to repair? Sigh.
blackjazzboy
Just called M1 shop hotline to check:
At Comex Roadshow for Note 5 - 32gb and 64gb handset Freebies - > Wireless charging pad, clear cover & OTG Cable
M1 Shop for Note 5 - 32gb and 64gb handset Freebies -> Wireless charging pad & OTG Cable
All while stocks last. :)
Hmm .. I just went down to IMM M1 shop ard 2pm and they told me no freebies if I sign up at the shop ....
anyone go to other M1 shop beside Comex and get the freebies when sign up for Note5?
love6969
Urrrgh ..... I was still thinking to go to M1 Shop after work as it is more convenient. Now am thinking twice if i should go to shop direct.
I spoke to 2 M1 CSO this morning to check on the freebies and i am called them again to make enquires after seeing your post. The CSO also confirmed that freebies available except the clear cover are all stocks last for all Note 5 sign up at the shop.
Maybe you wanna give M1 a call ?
Elijahonli
so only comex have the freebies?
