The Samsung Galaxy Note 5 Thread
Sinkie
oh, yours no sleeping beauty? okok noted. thanks
ok, i try to clear cache memory also
bcos beside not able to unlock, sometime when i am whatsapp-ing, my keyboard become freezed also, no matter how i press the letter, the letter will 'pop-out', but it will not be typed out
using swipekey now
not sure issit also same root problem of the sleeping beauty
ive been getting the 'sleeping beauty' thing since the day i got the phone.. prolly a week or so now.
updated to the latest update, and cleared cache after. still getting it.
so lazy to do clean wipe and all that.
any bros out here managed to solve the issue? if yes then shed some light as to how you do it. dont wanna wipe my phone clean and only find out it still persists. lol
tyia!
Sinkie
http://forum.xda-developers.com/note5/help/note-5-freezes-unlocking-t3188313
i found this thread discussing about sleepy beauty
Ok this is what worked for me.
1- Turn off your note 5
2- Press the volume up button and home button together
3- while keeping it pressed Press the power button
4-It will open The system screen find cache and clear it- (DO NOT DO ANYTHING ELSE) once its done choose the restart option
5- I also got a 33 to 40 mb update yesterday. Do not update from the fone use smart switch to update it will download a 1.4gb file meaning it will reinstall the system.
My fone for 2 days now is not freezing. before the problem occurred at least 5 to 6 times a day.
Just in case make a backup although i didn't loose any
data .
Let me know if it works for any of you.
at step 4 only can see 'wipe cache parition' nia. lol
not sure where to see the clear cache option
Chipero
Can share more about why you are impressed? :)
Sent from my cat messengers using GAGT
For a phone which is $280 ... a lot of things cannot complain loh ... I compare the M4 to my n5 ...
The M4 is lighter .. slimmer ... easier to hold ... also octa core ... 13MP rear ..5MP rear .. water resistance ... the ringtone loud enough for me to know the M4 is ringing ... LTE .. microSD up to 128GB .. Battery Endurance 81H
Really loh .. at this pricing ... this M4 is impressive. I can't wait for the M5 which is going to be out soon ... I surely buy ^^
My n5 which is about $800 more than the M4 ... what does it offer ? S-pen ? AMOLED ? Metallic Body ? Less bezel ? Battery Endurance 85H ?
Alkamizt
... I was using my n5 all the way till 5am just now ^^
Bro... sleeping beauty problem only comes in when your phone is asleep often and you are trying to wake it up occasionally :s13:
But you are right... so far after the update, I've not encountered it yet.
Kjonxx
Joined the note 5 club not long ago. Have anyone experienced not being able to wake the phone up from locked mode only until pressing the home and lock button a few times? Sometimes the screen will just hang at the lock screen. This happens to me occasionally and its especially irritating when i need to make an urgent call.
Not sure if this is a common problem.
Sinkie
I got sleeping keyboard problem lol
lxb_70
actually the "freezing" part issue i also kena from my note 3 AFTER update to lollipop.., sometimes i type half way also freeze for a while like 2 to 3 second.. is it becoz of 5.0 or onwards that will cause the "freezing" and sleeping issue?
tkl23786
Received my Note 5 64GB Black Sapphire yesterday (03 Sep)
First thing I did was to immediately update to the latest firmware and factory reset the phone
Used Smart Switch (PC version) to transfer everything from my Note 3 to Note 5
Been playing with it for a day now
So far, no issues (for now)
No "sleeping beauty" whatsoever
I am using the fingerprint unlock method
Ryder2912
Hi where can we get the pc version of smart switch? Unfortunately i backed up data on my note 3 using kies n now cant restore onto the note 5.
Grateful for any advice on this
Thanks
Sent from Samsung SM-N920I using GAGT
