The Samsung Galaxy Note 5 Thread
love6969
Went Clementi Mall M1 in the evening and there was the poster outside showing the freebies for Note 5. Did a recontract for note 5 black 64gb as was told only Comex show have the gold stock and shop only have black. Freebies only left wireless charging pad.
cj9404
what is note 5 model number
just bought note 5 today, now trying to register warranty online, but not sure what is note 5 model number, mine is note 5 32G black, i found model number SM-N920I on the box, but samsung website need some more letters like below:
SM-N920IZDAXSP
SM-N920IZDEXSP
SM-N920IZDFXSP
SM-N920IZKAXSP
SM-N920IZKEXSP
SM-N920IZKFXSP
SM-N920IZSAXSP
SM-N920IZSEXSP
SM-N920IZSFXSP
SM-N920IZWAXSP
SM-N920IZWEXSP
SM-N920IZWFXSP
which one to choose?:s22::s22:
RouK3ziLa
Hi where can we get the pc version of smart switch? Unfortunately i backed up data on my note 3 using kies n now cant restore onto the note 5.
Grateful for any advice on this
Thanks
Sent from Samsung SM-N920I using GAGT
if your n3 is still working you can use app called "smart swtich mobile" to xfer your stuff from old phone to new phone
anirudhks
SM-N920IZDAXSP
SM-N920IZDEXSP
SM-N920IZDFXSP
SM-N920IZKAXSP
SM-N920IZKEXSP
SM-N920IZKFXSP
SM-N920IZSAXSP
SM-N920IZSEXSP
SM-N920IZSFXSP
SM-N920IZWAXSP
SM-N920IZWEXSP
SM-N920IZWFXSP
Can choose any i called cs and theybsaid all same u can select.. i registered same way abd they say its ok
qw_er_ty
did anyone collected the free gifts ?
Is there choices of colour for the clear view cover ?
MenToy
Got my Note 5 just now at Comex show. For 64GB only got Dark Blue stocks.
Got the freebies: Wireless charging pad, samsung casing, samsung otg cable.
Those who want the freebies, better go by tomorrow. Got feeling will out of stock by tomorrow!
You bought from singtel or starhub?
I recontract starhub on 1st day for 64gb, but the supervisor insist 64gb no free bis.
keith
I recontract SH today, wireless charging pad + cover(silver), gold 64GB
tkl23786
SM-N920IZDAXSP
SM-N920IZDEXSP
SM-N920IZDFXSP
SM-N920IZKAXSP
SM-N920IZKEXSP
SM-N920IZKFXSP
SM-N920IZSAXSP
SM-N920IZSEXSP
SM-N920IZSFXSP
SM-N920IZWAXSP
SM-N920IZWEXSP
SM-N920IZWFXSP
Answer below
If yours is bought from Samsung stores...
SM-N920IZDEXSP
Should be this. Please correct me if i'm wrong. thanks.
N920I = note 5
ZD = gold ZK = black
E = 64GB A = 32GB
XSP = Singapore unlocked variant
MM1 = M1
SIN = singtel
STH = starhub
tkl23786
Thanks
Google "Smart Switch PC version"
Many links for you to download
Yeah, then use Bluetooth to transfer whatsapp database over :D
I used the mobile version at first, but found out WhatsApp data not copied
Tried the PC version and everything, including WhatsApp data, are all transferred. The PC version is better to transfer folders. No need to use any other method. Just use Smart Switch PC version to back-up your old phone and then restore into your new phone.
At least from my experience, the Smart Switch PC version is better in transferring everything from my Note 3 to Note 5.
Kies 3 does not work for Note 5.
nuscape
In case you r using wireless charger and it is not fast charge as it should...
I noticed that the wireless charger given as freebie last few days are the 'green colour box' one. This type is not the 'fast' type. Just FYI as my friends got this type and found the charging is slow. You must get the one written 'fast charge' on the pad. And the package is transparent plastic (and not in a box).
SKinny86
I got my Note 5, straight away changed CSC code to XSP to remove bloatware.
After which I upgraded to latest firmware and delete cache partition.
So far so good, never kena any sleeping issues yet.
